Will Someone Please Help With Canada Body Tag Decode
Old March 16th, 2012, 11:19 PM
ethn_bert's Avatar
I just bought a new project and need some help decoding the Body Tag. I know the important stuff like it is a 442 with a close ratio M21(still has all the tags on it). It also has the white/parchment bucket seats. I'm curious what D55 option is and what the paint code CGG is. The car was originally gold but that is all I know. The car does have the bright finish drip rail mouldings. What does the 1-4-22 mean?
D55M21
ST 68 34487 OS323844 BODY
TR 947 1-4-22 CGG PAINT
ethn_bert is offline
Old March 17th, 2012, 03:26 AM
Yellowstatue's Avatar
D55 is centre console and CGG is (C)white stripe? with (G) gold paint...
Yellowstatue is offline
Old March 17th, 2012, 03:17 PM
ethn_bert's Avatar
Old March 17th, 2012, 03:22 PM
ethn_bert's Avatar
1 - 4 - 22 -> First shift April 22nd DUH! It makes sense now!
Old March 17th, 2012, 04:07 PM
marxjunk's Avatar
m21 is well....m21..canadian cars have the trans options on the tag...
marxjunk is offline
Old March 19th, 2012, 09:39 AM
ethn_bert's Avatar
It turns out the car was not gold originally, the floor is a dark green. I also got some photos from previous owner showing a dark green. Does anyone know what CGG is?
Old March 19th, 2012, 09:50 AM
C= white, G=willow gold. When you said dark green, I first thought "Jade Gold" which is a metallic green, but you data tag says otherwise. I would get the Canadian documents, which give you everything for a car sold or built in Canada.
1969w3155 is offline
Old March 19th, 2012, 10:31 AM
ethn_bert's Avatar
Thanks, I looked up willow gold and that is very close to the color. The paint chips I found online say willow gold is CG. What is the second G?
I do plan on getting the paperwork from Canada. Im trying to decide if I want standard or the heritage package. Www.vintagevehicleservices.com I am not doing a numbers matching restoration; what is the benefit of heritage certification?
Old March 19th, 2012, 09:10 PM
C is the code for white, whether as the body color or for the stripe. GG means Willow Gold for the lower body color and Willow Gold for the upper body (the top). If the top were a different color, then it would be GB for example: Willow Gold with a Ebony Black top. if it were vinyl or a convertible top, then it would use a number for the color. G8 would be willow Gold with a Gold vinyl top. As you have indicated that it appears that the car was Willow Gold, then I am inclined to think that it was Willow Gold with a white stripe.
Old March 19th, 2012, 10:19 PM
D55M21
ST 68 - 1968 model production year
3 - Oldsmobile division of GM
44 - model 442
87 - 2 dr Holiday coupe
OS - Oshawa Canada Production
323844 - fisher body number
TR 947 - Parchment vinyl interior
CG - (part of a 2 tone color combination) - in this case refers to combination of Provincial white and willow gold - recommended as a color combo in the SPECS guide for 1968 production with parchment interior.
G - Willow Gold
D55 - sports console
M21 - transmission - heavy duty close ratio synchronized 4 speed; floor shift
I do plan on getting the paperwork from Canada. what is the benefit of heritage certification?
There isn't any unless you feel the need to spend extra money. Both the standard form and 'heritage' form will give you the same result, but the standard form costs about 40.00 less. The standard form will tell you all the Yada yada about production and all the vehicles options it was produced with.
Check them out: http://www.vintagevehicleservices.co...tion_73.45.pdf
The 'heritage' form is for documenting 'Canadian Built' cars. A wasted effort IMO since you already know your car was made in Oshawa.
http://www.vintagevehicleservices.co...ertificate.pdf
Your call.
Allan R is offline
Old March 20th, 2012, 04:36 AM
ethn_bert's Avatar
Thanks everyone! I appreciate all of your help.
Old March 20th, 2012, 07:34 AM
Allan, If this were a two tone paint car, wouldn't just be "CG"? Why the second "G"?
Old March 20th, 2012, 11:36 AM
oldsmobiledave's Avatar
Fyi
because upper & lower body paint colors are always listed seperately on the data tag.
Isn't CGG code for Willow Gold body with Willow Gold roof & white stripes?
oldsmobiledave is offline
Old March 20th, 2012, 08:37 PM
First letter = lower body color, 2nd letter = upper body color (top). Would the stripe be listed first or last? He has indicated that it appears to be willow gold, so why wouldn't the main color of the car be listed first. Is this spelled out in the Assembly manual? In '69 they went to a two digit paint code. Mine is 55 for Tahition Turquiose, as it is painted that color top and bottom, my data tag reads 55 55, so if his car was origianally Willow Gold top & bottom, wouldn't it be G G? Looking for definite answer/clarification, sorry if it sounds like I'm beating it to death.
Old March 21st, 2012, 04:03 AM
ethn_bert's Avatar
I first thought CG was willow gold and G was gold. Therefore I was thinking willow gold upper w/ gold accents(stripe?)
Obviously, I don't know. Lol
Old March 21st, 2012, 06:28 AM
stan 65 cutlass's Avatar
canada may have different names for paint codes,they did for 65
stan 65 cutlass is offline
Old March 21st, 2012, 11:42 AM
Good question, I got the info about the 2 tone right out of the SPECS booklet. What I'm wondering is if it could have been originally painted like the (68 HO) shown below, but with a white stripe?
Allan R is offline
Old March 21st, 2012, 09:05 PM
The stripe would follow the body like the H/O, but it's about 3/8 of an inch wide, and is about a 1/2" below the trim. My buddy has a '68 442 with the stripe, but I don't have any photos that show it.
Old March 22nd, 2012, 05:18 AM
Trying to remember member
wmachine's Avatar
This type code is certainly particular to the Oshawa cars. Based on what's been said, it does appear to be a stripe color code first. It also may be a W36 stripe designation too. Since none of the W30s were built there, this means it possibly is code shown exclusive to a 442 ordered with a W36 stripe.
A look at some other Oshawa 442 tags will clarify this for sure.
wmachine is offline
oldsmobilty
March 5th, 2015 03:31 PM
knoggin
April 17th, 2014 01:48 PM
pfergy600
September 28th, 2013 07:47 PM
mathieuaube
November 29th, 2008 11:21 AM
drtdobber
February 14th, 2007 01:16 PM
Quick Reply: Will Someone Please Help With Canada Body Tag Decode
