Lead or Octane Supplement for Unleaded Gas?
I still have some pinging when I put the spurs to my 57 Olds J2 (after a good engine warm-up). Anyone fixed this problem with lead or octane boosting supplements for unleaded gas? Perhaps there's another, better fix? The ping does not sound too serious. I have also heard that Shell gas has a zinc additive the older cars like...any comments?
Is the motor original? Adding a lead substitute can help with the pinging or valve noise in older motors and have also heard that adding a little ATF fluid to a tank of gas will help.There are also many off the shelf addatives that claim to reduce valve noise but have no idea which may be the best. I usually go with Lucas products myself when I can.Most of the products you are looking for basically are lubricants for the valves.
I agree use premium. When I had the J2 371 in my 57 Olds if I did not use premium it would ping, also check you timing and make sure it is correct if you are already using premium it should not ping. Like that pink!
Yep, using premium gas and still get the ping although not severe. She is a weekend warrior for shows and such, so I will try the octane boost additive until I can get the timing checked out.
Thanks for the input and comments. Dan
In my humble opinion
I have the same problem with my car , at least I did last year and I used a fuel addative to increase the octane. The premium fuel here is only 93 octane at the most so I thought trying to get the level up 5 points would help. I found that I am still getting some chatter when I put the pedal down. Over the winter I did a lot of work to the car including timing gear and chain , plugs , points , distributer cap , new rad ,all new gaskets and filters , fuel pump , transmission filter and gasket etc. etc. the next step will be to get the timing done but i have to take it to someone else for that since I have no light , maybe I can talk a buddy into coming over and doing it for me. might just cost me some beer. So if I still have the problem would you think that adding lead addative would be the next step?
You might be able to rent a timing light at your local auto parts store.
I think we need to clarify what we mean by "lead additive" here. There are basically 2 things here:
1. A "lead substitute", which is generally something for upper cylinder lubrication (to prevent valve seat erosion)
2. "Octane boost" products.
These are 2 different products that do 2 separate things. The vast majority of these products contain no lead.
Originally, real lead additives to gasoline did both. And there is (was at least) a "Real Lead" product that is genuine tetraethyl lead. That is the only product I know of that does both. Be careful, though, tetraethyl lead is very toxic and can be absorbed through the skin.
The stuff I have found around here is a lead substitute and says it prevents valve seat wear. It also says that it contains mineral spirits. So that would just be the lubricant and not an octane booster correct.
Correct. There are many octane boosters out there. "104" comes to mind.
There is a mechanic just down the road who specializes in old cars and I have decided that the car will be going there to get timed and tuned. he is also very good with electrical so maybe he can figure out the horn and wiper issues I have.He worked on dad's 52 chev 23 and 29 fords plus he has a few cars himself , though he is a Dodge man and has some big early 70's boats.
Col Wickham
August 29th, 2009 10:43 PM
