1959 Olds windshield trim
Old September 4th, 2014, 09:44 AM
Leroy701's Avatar
Hi, I'm in the process of replacing the windshield on a 59 2 dr ht, the old windshield was broken out. I'm having trouble getting the top and bottom clips to release and havent had any luck finding out how to do this yet.
Does anyone know the sectet?
Thank you
Leroy701 is offline
Old September 4th, 2014, 11:53 AM
59-59-59's Avatar
The top windshield trim is held in place with a couple 5/16 nuts. I think it was 6 total- 3 on the right side and 3 on the left side
59-59-59 is offline
Old September 4th, 2014, 12:29 PM
johns59super88's Avatar
If I remember correctly, after you unbolt the top clips and remove a screw from each end of the top, the windshield will push out from the top. Also must remove the cowl screen on the bottom (I think) to reveal the bottom clips which are not actually fastened to the body. This assumes you have both sides already removed. Also easier if you cut the rubber seal all the way around. The manual has a pretty good explanation and illustrations.
johns59super88 is offline
Old September 5th, 2014, 03:31 AM
Yellowstatue's Avatar
On a '57 the headliner must be dropped to expose studs and nuts that hold the upper trim on...'59 might have a stellar improvement??
Yellowstatue is offline
fzadnik
July 31st, 2015 05:48 PM
electra483
July 29th, 2015 02:57 PM
Oldssupreme
May 28th, 2013 05:35 PM
tailfins
March 24th, 2012 04:53 PM
delta
November 2nd, 2011 03:06 PM
Quick Reply: 1959 Olds windshield trim
