1964 442 power steering
I have a 1964 442 with manual steering. I want to convert it over to power steering. I think I have the correct pump, pulleys, hoses, and steering gear box. I do not think I have all of the pump mounting brackets. I only have one pump mounting bracket.
Does anyone know where I can get the power steering bracket lay-out arrangement? Does anyone have some close up photos showing the pump mounting brackets and how they mount to the 330?
Thanks dmw.
Thanks dmw.
No, they won't. The accessory brackets on the 1964 330 motors are unique to that year, and in fact the Jetstar 88 brackets are different from the Cutlass brackets. Remember that the 64 330 has the one-year-only driver's side water pump inlet.
1964 442 power steering pump pulley
With everyone's help I have found the correct power steering pump and brackets for my 1964 442.
I now need to remove the Pulley from the pump so I can clean and paint the pump and front bracket. The power steering pump pulleys on my other cars have a ledge or collar to accommodate a puller. This pump pulley hub does not have a ledge to accommodate a puller. The hub is simply smooth. The pulley is too thin to support a 3 jaw wheel puller. What is the trick on how to remove this pulley. Is there a special puller that clamps to the smooth hub?
Thanks,
dmw
Thanks,
dmw
nicks1966
January 12th, 2014 01:46 PM
