330/350 Flexplate
330/350 Flexplate
I’m considering installing a 350TH from a 1973 Cutlass into my 1965 Cutlass. Both cars are original. The 65 is equipped with the Jetaway transmission. I understand that its a pretty straightforward swap other than the shift linkage issue. I know that the crankshaft flange is different on a 65 330 than the cast crank 73 350. My question is, will the torque converter of the 350TH bolt to the flexplate of the 330?
I hope this make sense!
The converter bolt pattern will be the same. You can’t use the 350 FLEXPLATE on the 330, the bolt pattern is different.
To answer your question: the TH350 converter will work on the 330 engine.
