455 manifold
Old January 23rd, 2009, 11:03 AM
Pete Pino's Avatar
455 manifold
I have a 1971 cutlass that I took out a 350 motor with a 350 transition. I purchased a 455 with C heads. Can I use the 350 intake with the existing 4-barrel carburetor (for now until I can afford to change them) I will change the exhaust because it had single exhaust so I will add the headers now.
Pete Pino is offline
Old January 23rd, 2009, 11:10 AM
dan2286's Avatar
You can not use the intake. The 455 intake is much wider than a 350.
dan2286 is offline
Old January 23rd, 2009, 11:21 AM
Pete Pino's Avatar
455 intake
What is the least expensive way around this can recomend a manifold? aslo what about the carb?
Old January 23rd, 2009, 11:41 AM
Eddie Hansen's Avatar
pete I am sure ( at least in jersey) you can get a junkyard 455 manifold on the cheap, I say this because getting one from ebay could be cheap but the shipping would kill you. you would probably be able to use the 350 quadrajet , may not be the "optimum" set up but it would work.
Eddie Hansen is offline
Old January 23rd, 2009, 12:31 PM
citcapp's Avatar
Check craigslist, I have bought two edelbrock performer aluminum manifolds for 125 to 150 dollars each.
citcapp is offline
Old January 23rd, 2009, 12:51 PM
hamm36's Avatar
Lest expensive away around it? Put the 350 back in. Save your self some headaches.
hamm36 is offline
Old January 24th, 2009, 12:22 AM
oldsonharmont's Avatar
Be careful with used aftermarket aluminum intakes for the 455, some makes were prone to cracking underneath and then repaired. I found one at a swap meet for $80, but it was once cracked and had been welded.
oldsonharmont is offline
Old January 24th, 2009, 08:31 PM
Toro68
Guest
Posts: n/a
Can you use a 1968Toronado manfold unit? It has a lower profile than rear drive brothen.
Toro68
Guest
Posts: n/a
I have one kicking around
Old January 25th, 2009, 06:08 AM
2blu442's Avatar
Pete, shipping the factory cast iron manifold would be expensive due to the weight. If you would post your location there maybe someone on this board close by who has a spare laying around as Toro68 does. John
2blu442 is offline
Old January 29th, 2009, 09:32 AM
car guy
gearheads78's Avatar
Its no too bad. Fedex ground will do it for apox $35-40.00
Large size will eat your lunch before weight does.
gearheads78 is offline
Old January 29th, 2009, 09:36 AM
citcapp's Avatar
I agree, post your location. I have a toro manifold I am not using as well
citcapp is offline
Old May 17th, 2009, 08:28 AM
It's a sickness!
Toyaholic's Avatar
Just pulled my Toro intake for the tri-power install. If your close to Orlando, come pick it up.
Toyaholic1@gmail.com
Toyaholic is offline
Old May 17th, 2009, 09:25 AM
jensenracing77's Avatar
i also have a toro manifold. just let us know where you are.
jensenracing77 is offline
Old May 17th, 2009, 10:07 PM
442much's Avatar
You can buy a repro at the Parts Place for around $500. They even make repro "D" heads and a conversion kit for automatics changing over to manual transmissions.
442much is offline
the_boat
October 7th, 2009 11:32 AM
cowboyup1248
January 23rd, 2009 01:25 PM
Aussie67Delta88Custom
November 17th, 2007 07:36 PM
blue72regency
October 27th, 2007 09:47 PM
Quick Reply: 455 manifold
