66 cutlass 455 swap with Holley intake,to tall!
Old October 27th, 2013, 01:31 PM
eurojeff's Avatar
Unhappy 66 cutlass 455 swap with Holley intake,to tall!
Another rock in the road,slid a 455 with a 200R4 ito my 66 cutlass vert,had SB. I added a Holley street dominator intake & used the Qjet. Tried the OE a/f ,nix that & can't seem to find a aftermarket a/f that is about flush to close the hood. Any ideas,fixes seeing this is a nice & fairly common mod. somebody had to come across this issue? Thanks in advance
eurojeff is offline
Old October 27th, 2013, 04:54 PM
I use this:
http://www.ss396.com/mm5/merchant.mv..._Code=ATE-3907
There is also one wit a black lid.
oldcutlass is offline
Old October 27th, 2013, 06:00 PM
Ben
RAMBOW's Avatar
I'm using the same one mentioned above on my 66 455 w/ a torker intake and it fits... barely but it fits
RAMBOW is offline
Old October 27th, 2013, 06:15 PM
It won't work with an Edelbrock carb with a choke fyi for others.
Old October 27th, 2013, 06:20 PM
JPMDaddy's Avatar
http://www.jegs.com/i/Holley/510/642...oductId=743323
would this work?
JPMDaddy is offline
Old October 28th, 2013, 06:24 AM
eurojeff's Avatar
66 455 a/f to tall
I use this:
Thanks for info,oldsculass,any of the local guys carry this one,didn't see brand on the link,and did you have to remove the hood pad or trim? Also i'm wondering if the factory duals i installed on the 330 will also work withoe 455 manifolds with a little coerseing.
eurojeff is offline
Old October 28th, 2013, 06:51 AM
Originally Posted by JPMDaddy
No.
Old October 28th, 2013, 06:58 AM
Unfortunately that air cleaner can only be had mail order. I've seen them on ebay used and any of the Chevelle/ Corvette resto sites carry them. This is the lowest drop base setup out there.
I removed my pad because it was worn and oil soaked due to blowby belching from the original 330. Trim is still in place.
If your exhaust is at least 2.5 inch you can probably reuse your current exhaust, however I suggest either 455 stock or aftermarket manifolds, or run a set of headers.
Old October 28th, 2013, 09:10 AM
eurojeff's Avatar
Order a/f ,looks tight with the element hgt., but 2" will make a diff. (she said). Talked to the guy at Classic Exhaust says header pipes are larger but its the same bend worth a shoot. Starting to Look into headrs as well,what did u install,and how much agony was it?
eurojeff is offline
Old October 28th, 2013, 09:13 AM
Ben
RAMBOW's Avatar
Depending which manifolds you are planning to run, you may have to change out the drivers side pipe connection, as the SBO drivers side pipe has a tiny diameter (2" ?. The pass side pipe on SBO & BBO are same (2 1/4")
The angles will be slightly different- so they should be close. I think the main issue will be that drivers side manifold exit.
I am quite happy with my Headman comp headers on my 66, but they do take some massaging work to clear everything- which means taking them in and out a handful of times to get them right. I like the end result though... and much easier to connect up a true performance exhaust.
RAMBOW is offline
Old October 28th, 2013, 09:34 AM
eurojeff's Avatar
Ok through one now on to another issue. I'm looking at going to 17" wheels/tires,& how wide one can go in the rear with a 0 offset? I'm looking at 8" in the frontwhich should work ok,9" in the rear if it fits. Also will be installing a 8.5 10 bolt from a '73,but i think 66 Olds/Pontiac's & up had a wider 8.2 being the 8.5 had the same width,right?
eurojeff is offline
Old October 28th, 2013, 09:40 AM
Ben
RAMBOW's Avatar
73-77 had a different suspension design, and the rear end won't interchange with the earlier cars, regardless of the ring gear size.
64-66 a-bodies had the same axle width, and would be "correct" width for your 66.
67-72 a-bodies rear is 1" wider overall, but will still fit and bolt into your car.
The carrier is a different conversation- I'd recommend starting a new thread in the right section to ask rear axle questions, there are a couple experts on this site who can give you real specific answers to your questions and point you the right way.
Same thing on the wheels/tires questions.
One of the moderators (Richard / gearhead) had a 66 cutlass and he did alot of research and work lowering his car and fitting some big wheels on it, and it looked great. His build thread is still in the "major projects" section- do a search for 66 cutlass convertible and you'll find it. All you could possibly want to know about fitting big wheels on a 66... and a lot of other great detail work he did on that car.
RAMBOW is offline
Old October 28th, 2013, 09:46 AM
eurojeff's Avatar
ok understood,ill start another thread
eurojeff is offline
Old November 4th, 2013, 08:37 AM
eurojeff's Avatar
BTW oldcutlass that a/f worked great,tight fit just used a bolt to be flush. Now have to work out the Qjet bugs,loping idle,running lean,no mixture adjustment on the lft side,carb came with the running engine??
eurojeff is offline
Old November 4th, 2013, 10:00 AM
It was the only, and I mean only 14x3 air cleaner that fit under my hood.
Old November 4th, 2013, 10:42 AM
eurojeff's Avatar
What intake & carb are you running?I'm looking into edelbrock maybe
eurojeff is offline
Old November 4th, 2013, 01:41 PM
Mine is a BBC, I'm running a Performer and a Holley 3310.
Old November 4th, 2013, 01:58 PM
eurojeff's Avatar
455 a/f problem
Ah so you went off the rails a bit,I thought all the folks on this forum were stone cold OldsMos! What ever fits i guess,many thanks for tip,with all the little bumps in the road it speeds the process for sure.
eurojeff is offline
Old November 4th, 2013, 04:04 PM
Sometimes you run what ya got. I do have a 455 that I may refresh and install at a later date tho.
Old November 4th, 2013, 09:49 PM
lemoldsnut's Avatar
I used the above mentioned af base and a k&n filter top with no hood pad.
lemoldsnut is offline
Old November 15th, 2013, 01:49 PM
eurojeff's Avatar
oldcutlass What carb are you using & does it have elec choke?
eurojeff is offline
Old November 15th, 2013, 02:13 PM
Mine is a Holley 3310 vac secondary, mechanical choke. Why do you ask?
Old November 15th, 2013, 02:42 PM
eurojeff's Avatar
Well from what diff carbs with elec chokes i've seen,they sit to high & it doesn't look like a carb with an elec choke will clear the a/f base,but there again mayb there one somebodys found to work?
eurojeff is offline
Old November 15th, 2013, 02:48 PM
That A/F base was stock for a BB Corvette, Camaro, Chevelle, etc.. It should work with any carb other than a Carter AFB or Edelbrock. I know it fits a Rochester and a Holley Street Avenger 770 both with electric chokes, because my friends use them on theirs. The real limiting factor is the intake.
Old November 15th, 2013, 02:57 PM
eurojeff's Avatar
Well i talked to cliff ruggles and he recommended a 75 Qjet 850 reworked for my app,with elec choke,with an arm up for TV cable pull,although he didn't have a answer on the af housing fit. I guess its deceiving from how the pic looked he sent with the elec. choke. Thanks again
eurojeff is offline
Old November 15th, 2013, 03:02 PM
It should work. Key word is should.
Old November 15th, 2013, 03:32 PM
eurojeff's Avatar
I think that falls into the"easy to assemble",as in "kiss of death" usually.But what ya goin do!
eurojeff is offline
Old November 15th, 2013, 06:37 PM
I like the statement that a 6 year old can do it, but they never provide one.
Old November 22nd, 2013, 07:23 PM
Racer24ksi's Avatar
When I was racing Street Stock on dirt, they used to require 2 bbl carbs by rule. We used to take a stock air filter base that fit a small Rochester, cut out the area that fit the carb horn, and pop rivet and silicone that to an aftermarket filter. It also meant offsetting the center to clear the distributor, but you get the idea - its a flexible solution.
Racer24ksi is offline
Danp76
December 25th, 2018 05:53 PM
Greg Rogers
September 29th, 2016 05:55 AM
harry k
September 7th, 2011 08:56 PM
fast67vellen2o
November 17th, 2010 07:13 AM
Quick Reply: 66 cutlass 455 swap with Holley intake,to tall!
