71 Cutlass Timing
Old May 28th, 2012, 09:24 AM
Custom68's Avatar
71 Cutlass Timing
Hey guys, does anyone know the right timing for my 350 Rocket? My under hood sticker wasn't there when I bought the car. Any help would be appreciated. Thanks!
Custom68 is offline
Old May 28th, 2012, 09:37 AM
10-12 Btdc @ 1100 rpm with vac advance disconnected. More if your running an HEI.
oldcutlass is online now
Old May 28th, 2012, 09:41 AM
ASSuming a stock engine:
10° BTDC @1100 RPM for the 2bbl and the 4bbl with manual trans, 12° for the 4bbl auto,
BUT whatever works best for you is the best.
If you can advance it a few degrees and have it not ping and still start well, so much the better.
MDchanic is offline
Old May 28th, 2012, 09:47 AM
Custom68's Avatar
Sorry guys, should've mentioned that I upgraded to an HEI. I'm thinking maybe between 12-14 BTDC.
Custom68 is offline
Old May 28th, 2012, 10:03 AM
Feed it as much timing as it likes! I'd start 12-14! If you have a setback timeing light, set it @ 34-36 BTDC at 3000-3500 rpm with vacuum disconnected, and see where your curb timing falls.
Old May 28th, 2012, 10:08 AM
Custom68's Avatar
Thanks a lot! That should wake it up a little more.
Custom68 is offline
Old May 28th, 2012, 11:22 AM
Custom68's Avatar
Thanks a lot guys! Sweet spot was at 14 BTDC before pinging. Runs unbelievable!
Custom68 is offline
Old May 28th, 2012, 11:29 AM
Glad, to hear!
Old July 12th, 2012, 06:48 PM
Fastback71's Avatar
im upgrading from my 2bbl to an eddy 600 4 bbl. car will have headers and exhaust soon. should i also try the 12-14 BTDC with the factory point system or is that only for HEI?
Fastback71 is offline
Old July 13th, 2012, 06:17 AM
The curve on an hei is diferent, I would also recomend a setback timing light, and set your dwell @ 30, no more - no less. Then set your timing @32-34 @ what ever rpm the timing quis advancing with vacuum disconnected, usually around 3000 - 3400 rpm.
jpc647
June 10th, 2013 11:48 AM
dallasite21
April 1st, 2010 07:24 PM
al714
November 16th, 2009 07:41 AM
442scotty
May 13th, 2009 05:42 PM
dingusboy
April 2nd, 2009 02:56 AM
Quick Reply: 71 Cutlass Timing
