72 442 Dashboard Indicator Light Inquiry
Old August 20th, 2018, 09:26 AM
w1po's Avatar
My 442 has a small set of indicator lamps (2) on top of the dash. Can't find them on wiring diagram and don't know what they indicate. Here's a pic. Anyone know what this is for?
w1po is offline
Old August 20th, 2018, 10:16 AM
Gmcdually's Avatar
That is a fasten seatbelt light , should come on when put in drive if seat belt is not on , i
Gmcdually is offline
This is the 'fasten seat belts' light for cars that were manufactured after Jan 1972 AND had the U21 rallye pac gauges.
Allan R is offline
Old August 20th, 2018, 10:25 AM
Here's the wiring from the 72 Cutlass Assembly Manual
Allan R is offline
Old August 20th, 2018, 02:07 PM
The problem is that your Chassis Service Manual was printed BEFORE Jan 1972, and thus does not include this circuit. There is likely a Dealer Service Bulletin that covers it.
joe_padavano is online now
Old August 20th, 2018, 04:00 PM
Which is why I posted that diagram from the AM
Allan R is offline
Old August 20th, 2018, 04:03 PM
I know. I was simply informing the OP as to why he couldn't find it in his wiring diagram.
Old August 21st, 2018, 10:08 AM
w1po's Avatar
Thanks!
You guys are sooooo good with this stuff. Explains why I couldn't find it and I never even thought about the seat belt warning stuff. Much appreciated guys!!!
Dan
w1po is offline
Old February 4th, 2024, 11:42 AM
Jim Knights's Avatar
1972 Cutlass - Dashboard and Warning Lights.
I removed ALL of the dashboard indicator lights (speedometer, fuel gauge & warning lights) from my 1972 Cutlass to replace them, but then realized that the sockets are different colors. It looks like there are four colors - grey 194 bulb type, black 161 bulb type, green 168 bulb type and tan 557 bulb type. I'm pretty sure that the grey are the speedometer and fuel gauge lights. Does anyone know what the color sockets are for the warning lights (brake, gen, oil hot)? Thanks
Jim Knights is offline
Old February 4th, 2024, 11:46 AM
Old February 4th, 2024, 11:57 AM
Thanks for this information Joe, and the quick response. I'd also like to brighten the dash up a bit, do you have any experience with LED upgrades for the dash lights? Jim
Old February 4th, 2024, 11:58 AM
I have not personally used them in the dash. I love them as 1157 replacements.
scrappie
February 24th, 2018 01:50 PM
AJFink
November 9th, 2015 08:48 AM
BeenThere
April 7th, 2014 08:59 AM
costpenn
August 25th, 2011 12:13 PM
costpenn
June 26th, 2011 11:59 AM
Quick Reply: 72 442 Dashboard Indicator Light Inquiry
