'75 Salon steering box
Old April 19th, 2010, 05:38 PM
erudek's Avatar
Unhappy '75 Salon steering box
I put a new steering wheel on the car and found that the shaft was at around the 11:00 position with the wheels straight. I took it for an alignment, and they had a hard time with it. They had to adjust the tie rods several times. Finally, the mechanic adjusted the steering gear box and got most of it. It is not perfect, but decent. They also showed me the steering box is leaking.
I got in touch with the original owner, and he told me he had the steering box was replaced at one time. They also put the aftermarket steering wheel on for him. My question is this:
Could they have somehow misaligned the steering gear box and / or pitman arm and hide it by putting on another steering wheel? Are there alignment marks for the box and or pitman arm? Should I try realigning them? Where would the marks be?
I am planning to replace the box since it is leaking. Should I put a new pitman arm on also. How can i be sure I aligned them correctly? Big job? Easy, moderate, or difficult?
Thanks again, Eric
erudek is offline
agtw31
Suspension & Handling
15
June 14th, 2010 06:01 AM
d-666
Drivetrain/Differentials
October 2nd, 2008 03:36 PM
nohn
July 7th, 2008 11:55 PM
dynamic88
March 6th, 2008 09:58 AM
Quick Reply: '75 Salon steering box
