!968 442 firewall holes
Hopeing this is the correct forum for this subjec> Ive been searching high and low but I have not come up with any info on the general locations of holes in the firewall. I do realize and know the common stuff but there seems to be extra holes in places and before i go welding up stuff id like to know of they are add ons or not.
Here is a little back ground,
68 442
hardtop
bigblock
4 speed manual
Non a/c
does have heat though
non power brake
I do plan on adding the rally pack gauge set.
any picks or ideas would help my diagram I'm making. Matt
Drivers side
68 442
hardtop
bigblock
4 speed manual
Non a/c
non power brake
Drivers side
If you start with the Assembly Manual (PIM) Section 0 pages 140 & 141 you can see what was supposed to be there. Section 1-2 is also helpful
, But it is a start thanks for the info
I don't see a whole lot of extra holes. Keep in mind that you have holes for the speedo cable, the heater wire harness, the "christmas tree" fasteners that retain the sound deadener pad, the voltage regulator, the accelerator pedal mount, the accelerator cable, and a lot of sheet metal screws that go through the firewall.
