broken license plate frame - any way to recast this?
Old April 21st, 2012, 08:16 PM
69442murph's Avatar
I got my hands on a pot metal license plate frame from a local Olds dealership. It is cracked / broke in two places. Is there any way to recast this piece? I read here a while back someone was recasting dealer trunk emblems and thought maybe this could also be recast?
tim
69442murph is offline
Old April 21st, 2012, 08:18 PM
Chevy budget Olds powered
coppercutlass's Avatar
Im not sure on pot metal but cant it be brazed then re chromed ?
coppercutlass is offline
Old April 21st, 2012, 08:32 PM
hookem horns's Avatar
If not worth that kind of money/effort, you could always try JB Weld.
hookem horns is offline
Old April 22nd, 2012, 04:56 AM
Boldsmobile's Avatar
Do you have any jewelry manufacturers in your area? They can make a rubber mold of your frame. They will need to keep the two halves together some how and might also requires some additional finish work on the front side to hide the crack.
The emblems you were mentioning were done in RI. There are lots of jewelry manufacturers there. Just to be clear not a one off jewelry maker but a manufacturer who can make molds are pour material.
Boldsmobile is offline
Old April 30th, 2012, 06:38 PM
Octania's Avatar
they sell AL repair rod which can be used with a propane torch even. Weld together, smooth and finish to suit. Your item may be zinc die cast, I am not sure if this rod works on that, but would be easy to find out.
Maybe consult your local pro welding shop, see what they say?
Octania is offline
88hurstolds
April 15th, 2014 04:32 PM
Robert Kiedrowski
April 3rd, 2013 03:56 AM
69'442
July 20th, 2012 06:17 PM
w-30dreamin
March 13th, 2011 06:13 PM
blonzz
September 1st, 2004 04:35 AM
Quick Reply: broken license plate frame - any way to recast this?
