A car, B-C car or E car?
Old April 10th, 2013, 06:07 PM
jjokrm's Avatar
That is the question. How do you know which one you have? I was looking at my 68' assembly manual to reference the power steering bracket set-up and it has different scenarios that are dependent upon which car you have; A, B-C or E car?
jjokrm is offline
Old April 10th, 2013, 06:10 PM
starfire's Avatar
F-85/Cutlass = A body
88 = B body
98 = C body
Toronado = E body
starfire is offline
Old April 10th, 2013, 06:39 PM
jjokrm's Avatar
88 = B body
98 = C body
Toronado = E body
Awesome! Thanks!
jjokrm is offline
Old April 12th, 2013, 10:28 AM
It's even a "sticky":
GM Car and Truck Platforms
joe_padavano is offline
Old April 12th, 2013, 11:05 AM
88 = B body
98 = C body
Toronado = E body
I believe VC and Cutlass Flattop falls into A body and Custom Cruiser falls into C body.
Allan R is offline
Old April 12th, 2013, 01:51 PM
Correct
That's less clear cut. The 1977-1996 Custom Cruisers are technically B-body cars (sharing the same 116" wheelbase as the B-body sedans), but in reality the only difference between the B-body, C-body, and D-body cars in that time frame is the wheelbase. They are otherwise mechanically identical and share body parts forward of the rear doors.
I'm less well versed in the 71-76 CCs, but again, the B-body/C-body distinction is primarily wheelbase and trim level.
Old April 12th, 2013, 02:10 PM
I was inclined to lump the Custom Cruiser into the C body simply based on the body lines matching the Ninety Eight. That's really evident from 71-76 but when the bodies started becoming more 'generically similar' in 77 - 85 I agree the CC could be said to be more Delta related. Anyway, that's my line of reasoning and its just an opinion based on observation.
I did note that some references to the GM C body alluded that the CC and Ninety eight were simply 'stretched' versions of the B body platform. So your comment about wheelbase may be spot on.
Allan R is offline
Old April 12th, 2013, 07:58 PM
starfire's Avatar
Hey Joe, what's the body designation for your '62 F-85?
starfire is offline
Old April 12th, 2013, 08:26 PM
Alan, I believe the f85 was designated as an A body starting in 1961. Let's see what JP says.
Allan R is offline
Old April 13th, 2013, 05:51 AM
Actually, the 61-63 compacts (F-85, Tempest, and Skylark) shared the Y-body designation (and platform) with the Corvair. I see that the list in my post is incorrect. I'll fix that.
Old April 13th, 2013, 06:01 AM
starfire's Avatar
Do you mean "Z"? Your list has the Corvette listed as "Y".
And did they make a Corvair as late as '69? (Sorry, I know nothing about Chevys).
starfire is offline
Old April 13th, 2013, 06:17 AM
Yup. Note sidemarker lights:
The Corvair was replaced directly (though late in the year) by the Vega:
pic from here
MDchanic is offline
Old April 13th, 2013, 07:47 AM
I did mean "Y", which is why I need to correct the list.
And while the Corvair was produced through the 1969 model year, side marker lights were federally required with the 1968 model year.
Old April 13th, 2013, 08:26 AM
I know, but there is no other "evidence" of 1969 production that I could show in a photo, since headrests were optional in '68, as far as I know, and I think Corvair somehow avoided having to use a column-mounted ignition switch.
I'm no Corvair expert, but I don't think there were trim differences between '68 and '69 either.
MDchanic is offline
