Engine and transmission identification.
Old June 15th, 2022, 05:17 PM
Nlann's Avatar
Hello, I am new to the forum, if I posted in the wrong place or the information is avaible some where, please let me know. I recently acquired 2 engine, 2 transmissions, and a rear end from a collector who had passed. I'm hoping someone can help me identify what I have and help me get it to someone that needs it. They appear to be Olds rocket engines, atleast that's what the valve covers say. I don't know what Era they are, or if they have any value. Thank you for stopping by and helping.
Nlann is offline
Old June 15th, 2022, 05:49 PM
They both appear to be 371 cu in first gen Olds V8 motors. The one with #16 heads is a 1957. I'm not sure about the other one - are those #14 heads?
joe_padavano is offline
Old June 15th, 2022, 06:00 PM
OLDSter Ralph's Avatar
I think #14 heads are 1957, and #16 heads are 1958. The knowledgeable "ol timers" have yet to check in.
OLDSter Ralph is offline
Old June 15th, 2022, 06:11 PM
I know just enough about the early motors to be dangerous. The more I search, the more conflicting info I find. The one thing all the sources seem to agree on is that 14 and 16 heads are either 1957 or 1958.
Old June 15th, 2022, 07:42 PM
Joe P, I have to plead the same.
I got to know a guy who was a supervisor at Oldsmobile and seems to know things about 1957-58. He told me that 1957 had #14 heads and that they were prone to cracking and could have been replaced with #16's. This was important to me because I have a 1957 that I haven't started to work on yet.
Old November 24th, 2022, 07:43 AM
oldmercsrule's Avatar
Joe you appear to know your stuff about these older Oldsmobiles.
oldmercsrule is offline
Old November 24th, 2022, 09:55 AM
Proud Viet Nam Veteran
redoldsman's Avatar
Charlie Jones will probably speak up and then we will know for sure.
redoldsman is offline
Old November 24th, 2022, 06:53 PM
Phantom Phixer
Charlie Jones's Avatar
I'm in agreement with Joe and Ralph that these are 57 and 58 engines.
There should be a number STAMPED on the top deck surface of the block, between cylinders 1 and 3.
That should tell you exactly what they are.
You can view it from the top by looking between the head and the exhaust manifold. Like this;
Post this number if you can.
By all means don't scrap them.
They ought to be worth a couple of hundred each, More if they turn over by hand easily.
Charlie Jones is offline
OLDSter Ralph
June 21st, 2021 06:25 PM
spgosselin
June 6th, 2020 05:39 PM
Deni2nd
January 31st, 2017 12:03 AM
ah64pilot
March 3rd, 2013 08:08 PM
WolfmanG
January 16th, 2012 03:26 PM
Quick Reply: Engine and transmission identification.
