Epoxy a solution for stripped Q-jet fuel filter recepticle threads?
Hiya everyone,
I have a '70 455 a/t Q-jet with adios'd fuel filter receptacle threads. The unit is currently expoy'd-in so I can move the car in-and-out of the garage while I'm trying to source either another housing or entire carb.
I was under the impression that the epoxy is not a good long-term solution as the compound will (eventually) dissolve due to the gasoline chemical makeup. However, one of my dad's hot rod buds said that he (his pals) would regularly epoxy Q-jet base plates with no issues.
I would still plan on sourcing a replacement housing/carb, but is the epoxy solution as-is safe to drive around town?
Many thanks,
-Christian
Many thanks,
-Christian
theres a repair kit..its been avail for 35 years..its a new inlet that cuts threads..its been used for decades with success..ive installed them myself, but you may need an expert to install it.
i dont know if it will work once its been glued..its usually caught when it gets stripped..epoxy really screws stuff up..by the time you get the old out, the hole may be so big the repair piece wont work..i dunno
Okay, I found some other threads covering this topic. I should have looked first before posting this original thread but was more interested in hitting the sack instead.
Thanks.
Thanks.
JB Weld IS epoxy.
If the carb body is one with a desirable number or date code, have it heli-coiled. I have used the epoxy fix in my young and stupid days and it worked fine for as long as I had the car. The self-tapping repair fittings are another option.
jpaulwhite
February 25th, 2011 05:25 AM
