Ethanol in fuel
Ethanol in fuel
Now that's it's harder than ever to find gasoline without ethanol in it (especially in Canada), I was wondering what additives have people been using, to offset the water/ethanol in fuel problem? Also is a Fuel Water Seperator a recommended add-on to run in the fuel line? Now that spring/summer is on the way I'd like to make sure of a great running 350 and any feedback or suggestions about this ethanol "problem" would sure be welcomed, thanks!
Maybe say where you are located so that people in a similar geographical area can share their experience.
I'm in the desert southwest where it's warm and dry, so my situation is completely different from many others. I have never had any issues with ethanol fuel, either in my cars or yard equipment, even after sitting for a year or so. Other geographic locations can be much different.
Thanks for all the replies, In Saskatchewan the car sits for at least 6 months in the winter, this will be the first summer that all pumps here will have ethanol mixed with gasoline and I just wanted to see if anyone had any problems with this fuel blend. I've read a lot of articles saying how bad it is for the carburetor, fuel lines and tank, so it's always good to hear decent feedback from others who now use the "new" gasoline in the older engines.
Also, the accelerator pump in the carburetor can be degraded by ethanol fuel. In the carb rebuild kits I have used, the "old style" are black rubber and the newer ones that are ethanol resistant are blue.
Well okay I'll keep an eye on or replace the rubber fuel lines, since they're at least ten years old and not sure if they are ethanol friendly. Running a Holley (1850) 600cfm carb. hopefully no parts will be affected and make the engine run wonky (or will look about getting an updated rebuild kit), Added some Lucas ethanol fuel conditioner and upper cylinder lubricant in the last fill before winter storage. I'll continue adding that mixture this summer when refueling and hope to have a problem free 2024,
I restored my 66 chevelle convertible 20 years ago. Gets filled with 91-93 octane E10 since finished. Running a 750 Holley. That car has sat for up to 2 years without starting when I was in the middle of other projects (usually more like 4-6 months). Other than needing to recharge the battery, it always starts and runs fine. No additives, although I usually try to fill the tank before I put it away for the year.
It's more of an old wives tale than anything. I'd be more concerned about it "turning" or going bad before the ethanol eating the rubber. Seafoam is an excellent choice for an additive. That stuff is amazing.
I guess I read too much into the issues with ethanol. I had a few problems with erratic idling late last summer and after reading a few articles on the net, thought it may had to do with the "new" fuel. I can now narrow it down to maybe the fuel system, since the car had been sitting for years, I put a new sending unit (always showed full), a new tank and filter in, but didn't put on many miles before storing it away for the winter. So if ethanol isn't really the culprit, it probably was a dirty fuel system and had no need to worry about what I thought was causing the problem. Thanks all for your feedback!
Gela (Shell Canada)
Jun 28, 2022, 16:37 GMT+1
Hello,
Thank you for reaching out to us.
Please check the information below:
• Bronze (87 octane) - up to 10% ethanol
• Silver (89 octane) - up to 5% ethanol
• Shell V-power Nitro+ (91 octane) - No ethanol
• Shell V-power (91/93 Octane) - up to 10% ethanol, only available in BC and Manitoba
Do not hesitate to contact us if you have other issues or concern.Regards,
Gela
Customer Operation Specialist
Shell Canada
I had carb problems with stuff "sticking" with ethanol gas. No can find ethanol free gas in CA except for 5 Gal cans.. my 69 Olds stills a lot.. and had to rebuild the carb it seemed every other year Been using Stabil 360 Marine additive and better brands of gasoline like Chevron. since then no more problems
That's interesting, they're usually pretty classy joints here in Canada. I think there's a huge difference between the US and Canadian gas stations. We really only have about 5-6 different companies running all the gas stations in Canada and the differences between them are pretty well indistinguishable. Price differences are within a cent usually and you really can't get any type of specialty fuel at the pump. There's very very few small, independent, retailers here.
Gas stations in the US can be a big deal, especially in my neck of the woods.
https://buc-ees.com/about/
Actually, driving a classic diesel truck has taught me to avoid "mom & pop" gas stations and always go to a high volume location. Water contaminates diesel easily, especially if it sits in underground storage tanks for long periods of time. Seems like good logic to follow for my Oldsmobile too.
I’m kinda lucky…I got 3 ethanol free pumps close to me. But, usually it’s usually only 89 or 90 octane. I don’t think I’ve ever seen an ethanol free pump with 93 octane.
in my cars, especially newer truck I don’t worry as much about ethanol free since they were kinda designed for it.
BUT, my newish KTM 690 did have the plastic fuel filter inside tank delaminate at the seam and caused loss of fuel pressure. The shop said to replace with steel filter since they had seen way too many plastic filters delaminate from ethanol….the plastic was fine, it just eats the seam glue I guess after about 5 years.
