Fuel/Vapor Line Clips
On pg 110 of the Assembly Manual, it says there are a total of 7 clips, a black (#2) clip for the single 5/16" vapor line attached to frame under the hood on the pass. side, then 3 x (#1) silver clips (assuming silver b/c no color mentioned) for a 3/8" & 5/16" combo, then a 5th (#4) clip (for 3/8 & 5/16") on the flat side of the frame beside the lower control arm mount (not sure if this is silver or not, but I was sent a large gray clip that might be the correct one), then a 6th (#1) silver clip (for 3/8" & 5/16"), then a 7th (#3) 'pink' clip for a single 3/8" only.
I was sent no pink clip though, and only 6 clips, plus wrong colors it appears. I mentioned this to the co, and they sent me a black 5/16" clip (since that was not in the kit #OAF307) and a plain gray 3/8" clip (so I could paint it pink as they don't have pink).
The OAF307 kit includes 4 x black clips (for 3/8" and 5/16" lines), 1 large gray clip (no markings, but appears to be for a 3/8" and 5/16" line used possibly beside the lower control arm mount), and 1 x silver clip (for a single 3/8" line).
Either I am wrong, or someone did not research this well enough. Can anyone confirm correct clips, color, etc.? It is for my '72 Cutlass Supreme.
Thx.
Thx.
costpenn
September 16th, 2011 06:50 AM
