Glove Box Lock Question
There is a lock ring under the key bezel that needs to be tightened so it clamps the lock assembly to the glove box door so the lock does not spin. It's been over 25 years since I worked on mine so I can't really remember how to go about it. I remember inserting the key to remove the lock cylinder/bezel then tightening the locking ring. Hopefully someone with more recent experience will post up.
I read your post yesterday and didn't know how to respond until Kenneth touched on something.
If the cylinder can come out, its easy to tighten.
How to get it out, I don't know. Mine used to fall out on bumpy roads.
To re-install the cylinder, it will go in most all the way, then you need a small screw driver or a paper clip to press the last plunger,drops right in.
lemoldsnut
September 30th, 2015 10:05 AM
goldie442
August 21st, 2015 11:01 AM
justagirlfromla
March 11th, 2010 10:15 PM
