Lower Fan Shroud Hardware/Proportioning Valve wire connection
Question 1: My old fan shroud was chewed up at the bottom b/c it wasn't connected. I got a new fan shroud, but I'm having a hard time finding hardware to connect the bottom half. I bought some clips from OPGI, but I don't think that's right. There's 2 tabs at the bottom of the shroud with holes in the center of them. Is there some sort of bolt to connect it?
Here are the clips I got:
https://www.opgi.com/cutlass/1968/co...g/fans/CH4067/
Question 2: I'm rewiring my engine compartment. I got a new harness from American Autowire. Long story short I'm trying to hook up the brake light wire to the proportioning valve. I recently did a front disc brake conversion and the new proportioning valve wire connection is incompatible with the connection. I can buy a connection for $10 and splice it into the new harness. Before I do that I'm curious if the brass nipple from an original pv will screw into this new pv. I'd just rather not hack up a perfectly new harness...any suggestions? I don't have the original PV.
Thanks!
Thanks!
My guess is your 'clips' should look something like this. They attach to the lower part of
your core support and the bolt should go through the shroud.
Can't help with the wiring, good luck with her though.
Thanks!
Thanks!
oldspackrat
October 29th, 2017 07:38 PM
Giddy
March 10th, 2009 11:37 AM
