Oil filter bypass
Oil filter bypass
I have a question, if the oil pressure is high will it cause the oil filter bypass to be in bypass? Reason I ask is upon oil change I see metallic particles that are suspended in the oil. But upon cutting filter open nothing trapped by the filter media. Engine is a ‘65 400. Oil pressure is @ 40-50 psi at 1200 rpm.
Check to see if there is a bypass in the engine or in the filter that is not closing properly. Also check to see that the media in the filter is properly attached so oil cannot pass through the filter without passing through the media. Which filter were you using?
This does not mean the bypass is operating properly. The bypass may still be opening too soon. A check would be to change the oil filter adapter and see if the problem is corrected.
The suggestion to check the spring is a good one too.
You'll see a disk, about 3/8" diameter on the oil filter face of the adapter.
Here's what you would do:
- Press gently on the disk to see if the spring behind it seems to have remaining tension
- Look to see that the disk seats properly
Lots of good suggestions here but nobody has addressed the real problem.
There really should not be any metallic particles in the oil to begin with. You should consider taking an oil sample next oil change (or sooner) and sending it to get analyzed. Most parts stores sell the kits to do this and its not very expensive. Might let you figure out what is about to fail.
More than likely copper from bearings. I would keep a good eye on it and stop running it if it gets any worse so you dont do too much damage.
