Poor wiper blade contact
Old August 13th, 2022, 02:49 PM
jmcghee's Avatar
87 Cutlass Supreme . The bottom third , driver side wiper, does not apply apply enough pressure. Car calls for 18" blades, 16' have a better, contact patch. Have replaced the arm twice, Different brands . Any ideas?
jmcghee is offline
Old August 13th, 2022, 05:30 PM
72455's Avatar
Give the wiper arm a slight "tweak" bend downward....hold the arm with two hands and give it the tweak mid point between end of the wiper arm and the "fatter" section that's towards the mounting studs.
72455 is online now
Old August 13th, 2022, 05:58 PM
jmcghee's Avatar
Will try that
jmcghee is offline
Old August 14th, 2022, 11:05 PM
Also make sure the pivot is lubed and free to move. The spring needs to put a little downward pressure on the blade to clear the glass.
matt69olds is offline
RockAuto
May 15th, 2019 11:32 AM
67442nut
August 14th, 2014 09:12 AM
Green Turd Truck
March 17th, 2012 05:53 AM
jeff618
November 22nd, 2010 06:12 AM
442Harv
Bravada
October 11th, 2009 03:50 PM
Quick Reply: Poor wiper blade contact
