Radiator Leak -- 1960 Olds
Hi,
My radiator spring a leak today in the middle of the local Memorial Day parade. This is the second time this season that I've had radiator problems -- there was fluid coming out of the overflow tube when I took it out of storage in May. Was not able to figure out the problem then but have been watching it closely.
The radiator is coming out tomorrow and will go to the local repair shop. The thermostat is only a year old -- I replaced it shortly after I got the car. I want to get to the root cause and am wondering if it's something else besides the radiator.
Has anyone had a similar experience? You were all a big help diagnosing another problem I had with the rear brake cylinders.
Regards,
Mark
Regards,
Mark
Hi,
Regards,
Mark
Regards,
Mark
Mark, radiator pressure caps should be considered suspect if the coolant loss is limited to the overflow tube. Of course given the "junky" nature of many thermostats these days unless you have a Robertshaw thermostat in that engine it could be a bad thermostat again. Off brand radiator caps are also crap.
I'm compelled to make a correction regarding thermostats. Robertshaw controls is apparently no longer producing automotive thermostats and any inventory is only likely to be found on ebay. This leaves only one actually 100% domestically produced line of automotive thermostats and radiator caps. That product line is CTS.
http://www.cstinc.org/products.htm
Stant may still be making some things domestically but since 1997 have been British owned and merged into an automotive group which among some includes: Gates Rubber Company/Stant/Plews/Edelman/Schrader Bridgeport/Schrader Electronics and Dexter Axle.
We're getting to the point not even our automotive replacement parts companies are any longer U.S. owned. Sad state of affairs indeed.
Stewart Components, Flow Kooler, Milodon, and Mr Gasket, use the same design.
Norm
2blu442
June 29th, 2013 07:13 AM
