Repro Disc Brake Proportioning Valves for my '72 Olds
These new repro Disc Brake Proportioning Valves appear to be brass. Is this correct? Would the threads not strip fairly easy, especially when using S/S lines?
Would it be better to rebuild the factory Proportioning Valve? I am assuming they are cast iron?
Brass isn't correct, don't know how the brass threads handle stainless fittings.
I was in a hurry and got a brass one, it works okay but I don't like the way it looks.
I eventually want to get my old iron one rebuilt or get a rebuilt one, it leaks fluid around that button on the end you hold in when bleeding the brakes.
Supercars Unlimited has a valve rebuilding service and sells rebuilt iron valves with an exchange if they have it in stock.
http://www.supercarsunlimited.com/It...?CategoryID=82
Mocephus
October 1st, 2021 09:45 AM
L77F85
March 5th, 2014 09:34 AM
1k442
July 3rd, 2013 11:40 AM
1k442
April 18th, 2013 02:03 AM
