tire size for 1969 olds 98
Old November 9th, 2009, 06:33 PM
wjustinmartin's Avatar
I have been looking around the Internet for some sizes of wheels/tires for my car, but I am not sure if I have it right. What I am considering is 18" Foose Nitrous wheels with 255/45/18 Nitto 555 tires. After looking and figuring, I believe that size will work, but I am not sure and would like to defer to the more experienced here.
What about it? Is that a proper size, or do I have it wrong?
wjustinmartin is offline
Old November 9th, 2009, 07:09 PM
svnt442's Avatar
Don't you have skirts on that car? I think you're gonna want to do a test fit before going with a tire that large. I also don't know that I would want a tire with that short of a sidewall on a car that weighs almost 5000 lbs empty. Not that they don't have the load capacity (better check that), but hitting a pothole would be a bad day all the way around.
svnt442 is offline
Old November 10th, 2009, 06:12 AM
I would also be concerned about fitting that wheel and tire behind the fender skirts. If I were in your shoes I would take the car to a shop like Goodyear or Firestone and have them fit various wheel/tire combinations on the car until I found one I liked.
Olds64 is offline
Old November 10th, 2009, 09:49 PM
Thanks for the suggestions/replies
Old November 11th, 2009, 04:53 AM
Captain of my ship
wolfman98's Avatar
The fenderskirts are the biggest problem with putting those tires on. I had to change the hubcaps after I got my car because the spoked ones he had on always rubbed the centercaps at any bump or pothole. 245's may be a possability but as mentioned you may want to see if you can get them fitted before buying. Sounds like you are lowering the car?
wolfman98 is offline
Old November 11th, 2009, 09:54 AM
Yes, actually - I am considering having a coil taken out of the springs for a bit of drop.
BStone
August 25th, 2011 04:07 PM
rocketscientist
August 7th, 2011 01:52 PM
jkoester122
June 7th, 2011 07:25 AM
D Appeldorn
Wheels and Tires
April 23rd, 2010 11:15 AM
made in the usa
December 6th, 2009 09:10 AM
Quick Reply: tire size for 1969 olds 98
