Twin-snorkel air-cleaner base
Old April 9th, 2024, 02:33 AM
Aus78Formula's Avatar
Anyone recognise this air cleaner base? Possibly a later 442 Olds? I can't find the exact 1.5 snorkel arrangement along with having HEI. Thanks
by https://www.flickr.com/photos/196419001@N03/, on Flickr
Aus78Formula is offline
Old April 10th, 2024, 02:39 PM
oldoldss's Avatar
Does it look like this: 1970 1971 1972 Dual Snorkel Air Cleaner Olds Cutlass 442 - ClassicOldsmobile.com
oldoldss is offline
Old April 10th, 2024, 05:18 PM
Excellent, thanks!
Yes, that's the style it reminded me of but this is a later version. It has clearanced rear for HEI distributor, the short snorkel has more of a lip, the longer snorkel has no lip and possibly took a ducting hose??
It's not mine but one for sale, the guy didn't know what it was and I went to tell him and then realised it was slightly different to what I thought. The poor pics are from the ad. I've updated my first post, for some reason it only showed one pic and was tiny. I'm not sure why it is doubling the images, did that in my other posts also.
Old April 10th, 2024, 07:05 PM
The long snorkel also has provision for a plastic elbow for the corrugated inlet duct hose. Mid-70s something. The lid looks Chevy.
joe_padavano is offline
Old April 10th, 2024, 07:10 PM
It's kind of the mirror image of this Dodge truck unit.
Old April 11th, 2024, 04:13 AM
69HO43's Avatar
Olds used that same lid up through mid-86, and was chromed on an 80s H/O or 85/early 86 442 (I guess they borrowed that from the Corvettes) but that is NOT an Olds air cleaner (they went to a flatter top air cleaner lid mid-86 with no "bead"). Also, the main inlet would be on the left side and the mini-snorkel would be 180 degrees out facing the HVAC Evaporator housing if it were an Olds VIN 9 style air cleaner.
Resembles something that Chevy or Pontiac may have tried. Likely off a SBC of some sort is my guess. I don't keep up with their junk at all.
69HO43 is online now
Old April 11th, 2024, 04:32 AM
Thanks, good info.
Old April 11th, 2024, 02:51 PM
therobski's Avatar
So once upon a time a made a dual snorkel air cleaner out of two 425 Starfire air cleaners and after all the work make it look like the real deal never a cured to me that the lid height was higher than the 64 F-85 . Once I put my master piece on the 64- no hood clearance!
therobski is offline
Old April 24th, 2024, 08:11 PM
joes_olds's Avatar
The flange on the end of the short side doesn't resemble an Olds short snorkel based on the 70-72 link or the 74/75(?) version. Also the underside of the short snorkel looks different than any I have seen.
Closest I've seen is this one.
https://classicoldsmobile.com/forums...leaner-161305/
My guess would be homemade.
Cavet, I'm no Joe Padavano, respectfully.
joes_olds is offline
pnagy23
May 9th, 2022 03:12 AM
tdhill01
January 27th, 2016 11:41 AM
pureplaya442
Hurst/Olds
December 22nd, 2015 09:53 AM
Cincinnati Rick
November 29th, 2014 01:53 PM
grt05
November 3rd, 2009 02:30 PM
Quick Reply: Twin-snorkel air-cleaner base
