Water pump bolts on BBO
Old August 28th, 2013, 11:02 PM
H8D-67's Avatar
Was replacing my water pump on my newly bought cutlass and the previous owner had incorrect bolts for the water pump. One bolt was missing and one was incorrect and was not even tight. Does anybody know the original sizes to these bolts so I can replace them. I will post a picture of the pump so you guys know which bolts I'm talking about. Thanks
H8D-67 is offline
Old August 28th, 2013, 11:12 PM
H8D-67's Avatar
The bolts I'm talking about is the one directly under the pump outlet and the bottom middle one. They are right next to each other. Any help would be great, thanks.
H8D-67 is offline
Old August 29th, 2013, 06:19 AM
"Trying to fix her right"
dfire25's Avatar
Inline Tube sells the hole set. Look under timing chain cover bolts. If anything you can see the correct bolts that are used and compair with what you have.
http://www.inlinetube.com/PDF%20cata...dsmobile04.pdf
dfire25 is offline
Old August 29th, 2013, 07:08 AM
XCELERATIONRULES!
Nasty455's Avatar
The one under the pump outlet is the longest bolt of the set..has threads on both ends for accessory mounting.
Bolts on bottom are small 1/4 20..strickly for holding pump to timing cover.
Nasty455 is offline
Old August 29th, 2013, 11:38 AM
H8D-67's Avatar
Hmmm the long one with threads on both sides goes below the pump outlet? I remember that bolt when i took it out, it was in the hole right above the outlet. Sounds like mine were all messed up.
H8D-67 is offline
nolabigdawg
October 25th, 2014 11:50 AM
delta254
June 12th, 2013 05:42 AM
RAMBOW
August 24th, 2012 11:18 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
72Ctlss
June 23rd, 2009 03:12 PM
Quick Reply: Water pump bolts on BBO
