Welding around control arm mounting hole with arm attached?
Old December 18th, 2011, 09:37 PM
oldzy's Avatar
Just wondering if anyone has put welds on a control arm (the hole on the frame) with the arm attached and bushings installed?
I still have to tack weld a washer on the outside of the rearmost drivers side lower front control arm hole b/c it is wallowed out a bit... but the control arm is on (with poly bushings). Just curious if the heat will destroy the poly bushing. I just don't like playing with compressing coil springs is all, but will do so if need be. tx
oldzy is offline
Old December 18th, 2011, 09:43 PM
Rickman48's Avatar
Poly bushings will melt, just like rubber!
Best way is to do it right - pull it off. Better anyway, as nothings 'loaded'!
Granted, PIA, but I'd be looking for another one - not a dependable repair.
Rickman48 is offline
Old December 18th, 2011, 09:45 PM
oldzy's Avatar
thx.
It is the frame hole that is wallowed out, not the control arm. I was not clear.
oldzy is offline
Old December 19th, 2011, 03:25 AM
You can take a chance if you want - with the bolt out you might get away with not melting it, but I wouldn't count on it.
No doubt the best way is to take it apart.
MDchanic is offline
Old December 19th, 2011, 06:42 AM
Run to Rund's Avatar
You can use a floor jack under the spring pocket and lower the A arm just enough. It would be best if you can loosen the other bolt but leave it in, because if both legs of the A arm come out, you will have more work getting them aligned again into their brackets.
Run to Rund is offline
Old December 19th, 2011, 06:43 AM
You can also use a piece of 3/16" or 1/4" thick steel that is bigger so you aren't welding right on top of the bushing.
RAMBOW
March 21st, 2022 02:48 PM
rcdynamic88
Brakes/Hydraulic Systems
August 6th, 2014 07:41 PM
RandyS
August 24th, 2013 10:33 AM
RAMBOW
August 18th, 2012 12:00 PM
oldzy
34
May 1st, 2011 06:14 PM
Quick Reply: Welding around control arm mounting hole with arm attached?
