1969 H/O Rear Brakes
Where are you getting this information? My parts books dated Sept 1968 and Jan 1972 both show exactly the same rear brake shoe part numbers for all 1968-69 Olds A-body cars except the Vista (which used the wider 2.5" rear shoes).
Interestingly, P/N 5467472 was previously used on 65 A-body and 64-66 Jetstar 88 cars. They are not the metallic linings used for Police applications. Since the rear brakes are pre-installed on the rear axle housing, that would mean that the rear axle assemblies for the H/O would have had a unique part number.
Here's what they look like.
The final supersession sprawling web and tangents I can find on these ends up with 18029594.
Organic.
ACDelco 18029594 ACDelco Gold Brake Shoes | Summit Racing
Yes, besides the different brakes, the 69 H/O axle assembly showed a different production part number (406222 with 3.23, 406223 with 3.42 and 406224 with 3.91), a different two-letter code (SH, SJ, SL), but used the same brake drums, axles, and center section/gear set part numbers as a G80 equipped 442.
Organic.
18029594 is just the generic 9.5" x 2.0" brake shoes that are shown for just about every GM application. That P/N specifically is for the 1985-90 B-body cars with the small brakes. It superseded just about every prior 9.5 x 2.0 application. Whatever was unique to the 5467472 shoes will not be featured in these.
Joe, I'll concur with you comment regarding 18029594 not being a meaningful reference. I'm thinking of the photos you posted of the 1969 part number shoes having riveted linings. I have a set of the first superseded number and they also have riveted linings. Could the 1969 442 original shoes possibly have bonded linings and hence the different part number?
