1969 hurst olds number. 801
Old September 15th, 2023, 07:58 AM
Ugga1's Avatar
Found a 69 today that might be up for sale. It's number 801 built for Tom burns. Anyone know anything about this car?
thanks
Ugga1 is offline
Old September 15th, 2023, 09:39 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
No but check here:
https://www.hurstolds.com/
And here:
https://classicoldsmobile.com/forums...gistry-127218/
This page is old. I dont see that number listed.
http://hurstolds.oldsgmail.com/69hoinfo.htm
droldsmorland is offline
Old September 15th, 2023, 11:37 AM
Is 801 the Demmer number or the dash plaque number? The registry lists the Demmer numbers. The dash plaque numbers were issued sequentially when (and if) the owner sent in the paperwork for the plaque and are unrelated to the Demmer numbers.
joe_padavano is offline
Old September 16th, 2023, 02:19 PM
Ugga1's Avatar
Dash plague number.
Ugga1 is offline
Old September 16th, 2023, 05:48 PM
FStanley's Avatar
Originally Posted by Ugga1
Dash plague number.
Better check with Kurt KArch as I have heard not all post cards were sent in. like about maybe about 60% of all the cars that were sold..
FStanley is offline
Old September 16th, 2023, 06:15 PM
So can someone explain the Demmer 801 vs the dash plaque number?
As in how do you know the Demmer number. Is it in the VIN?
no1oldsfan is offline
Old September 17th, 2023, 01:51 AM
69HO43's Avatar
VIN doesn’t tell you anything other than one car was built before or after another car on the assembly line at Olds.
Looking at VIN sequencing it appeared they were building them spaced apart a little here and there as they loaded up trucks to take them to Demmer. Probably wanted to dribble them out to keep from building up on the Olds lots yet moving fast enough to keep Demmer busy. I’ve heard nothing about the logistics operations concerning the 69 H/O from anyone or anywhere. So can only speculate how they did it based on other Tier 1 vendor conversions.
Demmer number was the number on the receipt to Oldsmobile when the car was dropped off. It’s not really an official number of anything as far as sequencing. It’s just that as they were handling transfer paperwork it was on sequentially numbered pads. Had nothing to do with GM tracking or a car’s VIN. It was a Demmer thing so they could easily tell if a car went “missing” since it was on the numbered pads. This is traditionally the way to absolutely verify a particular car was converted to an H/O because if it had a Demmer number, there is documentation. And the Demmer number had no bearing on when the car got pulled into the building for conversion. Car with Demmer number 70 could have been converted that morning with Demmer car number 59 late that afternoon. Rando.
The Hurst plaque number was just the registration number Hurst Performance gave to the owner if they bothered to send in the registration card. The plaque could be applied anywhere or not at all. Most ended up on the dash woodgrain part. Some even on the glovebox which could very well have made it to another car. The Hurst plaque number was first come first served depending on when you mailed in the registration and is not a meaningful way of verifying an H/O as to the best of my knowledge, not everyone registered their car and no one has come up with any Hurst registration documentation that could be traced to a particular car’s VIN.
69HO43 is offline
Old September 17th, 2023, 02:00 AM
69HO43's Avatar
Another thing to consider is that there were likely very few cameo white with black bucket auto 69 442s built in Lansing between the H/O campaign dates on the body tags that weren’t destined for H/O conversion.
69HO43 is offline
Old September 17th, 2023, 07:18 AM
Thank you for all that information. 👍
Old September 17th, 2023, 06:04 PM
69442murph's Avatar
The pick up and delivery tickets ( copies ) on my car...179
69442murph is offline
Old September 17th, 2023, 10:31 PM
69HO43's Avatar
Thanks for that. I haven't looked at any of my "paperwork" in a million years. My mind is going away. My bad on the Demmer number being on the intake paperwork. Let me rephrase my screwup that at SOME point the car was assigned the Demmer number after the car was dropped off. 69442murph has the dropoff and send off receipts showing. Note the send off receipt shows the Demmer number circled on it next to the VIN. There's one more piece of paper to which is the Demmer final quality check and this is where the car was signed off on. This was where the pre-printed "Demmer Number" can be found.
Basically, if Kurt Karch has any paperwork with your VIN on it, that is verifiable proof your car is a 69 H/O.
Here's car #24's slip. The VIN is lower than mine (#43), yet mine was shipped out on 4/1. This one is dated 4/7. Regardless, this number has no bearing on the dash plaque number.
69HO43 is offline
Old September 18th, 2023, 09:03 AM
1969Hurst's Avatar
See if you can get a pic of that dash plaque, I'm going to say there is no way they made it up to 801 assigned dash plaques as you only received one if you sent in the specific dash plaque paperwork. I've never seen or heard of a dash plaque number higher than the 500's. I've seen people make their own based on the Demmer number or just completely fabricate a number.
The 'font' and style of the original dash plaques is usually easy to discern from a fabricated one. 801 has a higher likelihood of being the Demmer number if legit. Get the last 6 digits of the vin.
1969Hurst is offline
Old September 18th, 2023, 10:16 AM
69HO43's Avatar
excellent point. No way over 800 owners sent in the registration card.
if it is the Demmer number, it’s by fat chance since I don’t think Kurt got that box. I don’t recall. But it would be a fake because the dash plaque had nothing to do with anything else.
69HO43 is offline
Old December 5th, 2023, 12:32 PM
Assisting the OP w/ updated information:
Finally got the vin on that 801 dash plaque car
344879m359262
anybody know anything about this car?
https://classicoldsmobile.com/forums...5/#post1539435
Vintage Chief is offline
Old December 5th, 2023, 01:35 PM
69HO43's Avatar
Car VIN 359262 was Demmer car #320. It definitely has paperwork from Kurt Karch.
That's like a hair over the first third of the ones that were logged in at Demmer. Plaque 801 I think is wildly inaccurate. Unless they took their sweet-*** time mailing in the stuff and assuming 800 other owners mailed theirs in all in front of this car's. Never saw a dash plaque in the 700s let alone 800s.
Someone get a picture of that plaque. Maybe 301 at best? Just can't see 801.
Now, far be it from me to say, but I recall in the late 90s, there were SEVERAL 69 H/O gloveboxes listed on ebay from actual cars and some had dash plaques attached. What numbers and where they ultimately ended up is anyone's guess.
69HO43 is offline
Old December 6th, 2023, 08:16 PM
1969Hurst's Avatar
Be very WEARY of that car....
Per the below pic, if this is the VIN of the car... as in if this pic is the same as a vin pic for the car in question, it is a clone.....
Get a pic of the cowl tag... compare it to the one below, this cowl tag is not correct for a 1969 H/O yet was on a M359262 VIN clone...
If you are familiar with the ways VIN's are stamped and the fonts used. etc, you can surmize by looking at the VIN pic it is not correct.
This one pictured also had a "dash plaque" for.... not 801 Tom Burns..... but......802 Tom Burns...
Old December 7th, 2023, 03:15 AM
I really love that Dymo Labelmaker VIN tag...
Old December 7th, 2023, 07:46 AM
69HO43's Avatar
Hahaha. It has a green bench seat in it (942). WTF? They should be 930 black strato buckets. Also, why the 34487 on the cowl tag? Should be a 36 Cutlass code.
Wow, that is one messed up car. Wonder whatever happened to the REAL car?
69HO43 is offline
Old December 7th, 2023, 09:29 AM
1969Hurst's Avatar
if you look closely, that is not a LAN Lansing cowl tag, think its BL referring to Linden.... had to look that up.
Kurt is aware of the original car, long gone, detroyed, fire, deteriorated, etc..... Car in my photo's is a "Partscaster"... using a guitar term there... cobbled together... again, not sure if it is the same as the O.P. car in question...
Here is a pic of the 'boxed' rear lower control arm from my example for your enjoyment.....
Old December 7th, 2023, 01:18 PM
69HO43's Avatar
Wow. Just...wow. I'd say "BOTCHED" instead of "BOXED" LCA.
69HO43 is offline
Old December 7th, 2023, 01:57 PM
briane's Avatar
A question, stemming from curiousity, did the person contemplating selling this car disclose its actual heritage?
briane is offline
Old December 8th, 2023, 11:13 AM
This is interesting. I saw an H/O clone, same year, at a car auction local to me 2.5 years ago. I took pictures of the vin and cowl and other things, and the cowl tag was from Fremont, with the same botched 50 50 paint codes.
That's two cars with a faked VIN to what would be a correct number, and a cowl tag faked to the correct paint code, yet the plant code on the cowl tag is left untouched. I'm thinking they fabricate the faked vin, and modify the cowl tag to fit the paint and never have a correct cowl tag from the original car. The VIN may be fabricated to match a 455 VIN derivative already there on the block as well. I guess punching in Lansing would look too faked.
Koda is offline
Old December 8th, 2023, 01:31 PM
1969Hurst's Avatar
Yep, this is why I'm not a fan of 'clones'... to each your own, thats your own gig, but I won't help out with any info for someone trying to build a clone. First, why would I want to dilute the uniqueness of my own car. But more importantly, even with the best intentions, the car will eventually get sold and possibly pass thru an auction or two and down the line its provenance will get lost. I know.... "buyer beware" and all... and luckily people can reach out to individuals or Forums to seek assistance..
Here's another treat off the cloned car..... again, do not know if this is the same vehicle the O.P. was inquiring about. If you are familiar with how the spoiler attaches, this will make you cringe... even if you are not, I think it should cause a double take...
Old December 8th, 2023, 02:21 PM
This among other threads is why I love this site. So many knowledgeable people here. I love it.
Clones suck when represented as real. I hope this "801" car wasn't sold as real.
Green bench seat 69 Hurst Olds would be Super rare!
Old December 8th, 2023, 04:16 PM
There's a dude cloning a 72 and proud of it, posting on all the facebook pages. He wanted to know where to put the H/O emblem on the trunk, since it has been seen in two places. I told him either was fine since his was a clone. He mouthed off at me, saying I didn't get it that he was trying to stay as close to the car as possible. I lost patience and told him no one wanted him making a clone; it's just that everyone is too polite to say so. Hopefully, he'll stay gone.
Koda is offline
Old February 5th, 2024, 03:53 PM
Bigdirty61's Avatar
Car is fraud
car
Bigdirty61 is offline
Old February 5th, 2024, 06:46 PM
69HO43's Avatar
That should buff out.
69HO43 is offline
ericjimmysfla
May 22nd, 2015 07:50 AM
Funkwagon455
August 28th, 2014 09:22 PM
w30hurstolds
Hurst/Olds
25
May 29th, 2014 04:50 PM
BlueCalais79
Hurst/Olds
15
April 8th, 2014 10:17 AM
wizarddrummer
May 4th, 2011 09:55 AM
Quick Reply: 1969 hurst olds number. 801
