1975 h/o 455 ?
Old August 5th, 2009, 03:48 PM
bullet1's Avatar
1975 h/o 455 ?
have a chance to pick up one of these needs full restoration.body panels look straight would need floors.what would be fari offer?also how easy are parts to find for these?
bullet1 is offline
Old August 6th, 2009, 06:58 PM
Cameo White's Avatar
Smile
Parts for the mid 70's Colonnade style cars are tough to find. There is essentially no repro market to date, so you will either be sourcing good used stuff, or trying to find NOS stuff (which doesn't seem to be that plentiful).
Personally, I like them a lot. But, the market for them is fairly limited. If you like it and want to do for your own satisfaction, go for it, knowing the above. Just don't think you are restoring it as an investment, because the prices so far don't justify it.
Cameo White is offline
Old August 7th, 2009, 05:59 AM
Past Administrator
Oldsguy's Avatar
That body style is definitely unique, you will have your work cut out for you. On the good side, demand seems to be a little less than the earlier or the later models so you may be able to offer less. If the car is running and mechanically sound maybe you could offer $1500 to $2000???
Oldsguy is offline
Old August 7th, 2009, 06:01 AM
Truthfully, you shouldn't buy a car to restore thinking you are going to make money on it. Not unless you are somone like Jay Leno.
Olds64 is offline
Old August 9th, 2009, 07:43 PM
1969Hurst's Avatar
Excellent point, especially on the '75.... a full restoration would probably quicky exceeded the true value of the car. May not matter if you intend to keep it.
1969Hurst is offline
Old August 25th, 2009, 12:44 PM
wazoo's Avatar
'75 H/O
Did you pull the proverbial 'trigger? I may be interested in several parts for my own '75. I've already exceeded the car's value so I buy parts for the sheer thrill of acquisition because I am strongly desirious of acquiring and possessing most of remaining pieces on earth and am known to travel far and wide to find them....wazoo
wazoo is offline
Old August 26th, 2009, 06:54 AM
66400's Avatar
Austin, Tx.
White 350 H/O rough car for 1,000.00
Henry
66400 is offline
my83432
September 16th, 2010 11:17 AM
O's_Car
January 2nd, 2010 09:22 PM
1960 Ninety Eight
March 29th, 2008 09:02 AM
joyce
February 25th, 2007 06:12 PM
Charger1973
January 10th, 2007 01:02 AM
Quick Reply: 1975 h/o 455 ?
