h/o package parts deal
Old August 13th, 2013, 07:06 AM
camshaw's Avatar
camshaw is offline
Old August 13th, 2013, 08:24 AM
camshaw's Avatar
camshaw is offline
Old August 13th, 2013, 02:40 PM
65B01Delta's Avatar
I'm sure somebody will chime in on the parts. I would if you were not so far away.
65B01Delta is offline
Old August 13th, 2013, 03:34 PM
Octania's Avatar
bunch of HO 1969 parts:
D heads- Used to be $5000 pair, more like $2000 nowadays
HO intake - yeah, right [EXCEEDINGLY scarce]. Get the exact casting number. J-398662 $100 or two; J-405233: several thousand dollars probably.
manifolds - repro's are $300-400 a set so unless PERFECT, maybe 300
distributer - exact number and date matter greatly. I will guesstimate as much as $1000 for the ultimate one.
complete motor minus the carb and aircleaner,
motor spins free and needs a rebuid as he drove it everyday and stacked up the miles.
Red paint on motor is still visible and chrome on covers is flaking..
With D heads? 5k maybe?
OH trans, and the posi rear end out of the car
Not sure but there's an OH trans that is NOT Hurst/Olds- maybe it's 1968. Ck the VIN stamp, maybe the h/o owner is looking for trans and engine.
and the original hurst shifter and cover - I'll guess hundreds with the cable and everything.
five chrome and silver HO 15" wheels - Several hundred
spoiler and hood scoop... - several hundred $
glove box lid with HO emblem - a few bucks, maybe 100 or 200
broken HO scoop with markings, and also another complete oem scoop that he had found - a few more hundred.
Octania is offline
Old August 13th, 2013, 07:32 PM
camshaw's Avatar
camshaw is offline
Old August 13th, 2013, 09:31 PM
It's a sickness!
Toyaholic's Avatar
What color is the steering wheel?
Toyaholic is offline
Old August 14th, 2013, 09:09 AM
Better be black if it's from a 1969 H/O.
joe_padavano is offline
Old August 14th, 2013, 02:00 PM
camshaw's Avatar
camshaw is offline
Old August 14th, 2013, 05:15 PM
Old School Olds
tru-blue 442's Avatar
Shoot some pics of this stuff.
If it is what you say, it will go
quick for nice $$.
tru-blue 442 is offline
Old August 14th, 2013, 09:26 PM
camshaw's Avatar
camshaw is offline
Old August 18th, 2013, 09:54 AM
Octania's Avatar
The exact casting on that intake will be the money shot
There should be a "J" in the depression at the front, but there are two "J" manifolds. The 6-digit number ID is atop, aft of the carb.
Octania is offline
Old August 18th, 2013, 12:03 PM
camshaw's Avatar
camshaw is offline
Old August 18th, 2013, 08:46 PM
65B01Delta's Avatar
Pic's ?????
Old August 18th, 2013, 09:26 PM
camshaw's Avatar
camshaw is offline
Old August 19th, 2013, 06:35 PM
camshaw's Avatar
camshaw is offline
Old August 19th, 2013, 07:21 PM
Old School Olds
So Cam, whatever happened to #114?
Did it go to the wrecking yard?
Old August 19th, 2013, 08:02 PM
camshaw's Avatar
camshaw is offline
Old August 20th, 2013, 04:54 AM
Old School Olds
If you could find a 69 S or a 442 shell,
you could really have a wolf in sheeps
clothing so to speak. That would be nice
to keep the drivetrain all together in one car.
Old August 20th, 2013, 02:59 PM
camshaw's Avatar
more info
camshaw is offline
Old August 20th, 2013, 03:03 PM
camshaw's Avatar
more pics
camshaw is offline
Old August 20th, 2013, 04:09 PM
camshaw's Avatar
camshaw is offline
Old August 21st, 2013, 04:47 PM
Octania's Avatar
That's quite a stockpile
I'm glad to see at least that much got saved.
Those intakes are not easy to find.
Hey can I borrow that intake for a few days?
It'll come back blasted clean to bare cast iron.
Octania is offline
Old August 21st, 2013, 05:10 PM
Bernhard's Avatar
How much for the steering wheel?
Bernhard is offline
Old August 21st, 2013, 08:21 PM
camshaw's Avatar
camshaw is offline
Old August 22nd, 2013, 07:21 AM
Guy Fillinger's Avatar
Carburator
Cameron
Ilooked at your posting a EBAY. You showthe carb.and give the number as 7029254 That is not the right carb. for the 69 ho the the carb they use on all 69 HO's is 7029251 a very comon carb. Here is the good news the 7029254 carb is for a 400 W30 ram air car a much more valuable carburator. I hope thishelps you out
Guy Fillinger
Guy Fillinger is offline
Old August 22nd, 2013, 07:34 AM
camshaw's Avatar
camshaw is offline
Old August 22nd, 2013, 07:54 AM
carb.
I'm always willing to help as long as I don't have to do anything.
Guy
Old August 22nd, 2013, 07:59 AM
camshaw's Avatar
camshaw is offline
Old August 22nd, 2013, 08:12 AM
carb.
What probably happen is the original owner had touble with his original carb. So the dealer put a replacement carb. on the car. They never look at the number. what ever carb. they get in they put on. Thats what happened to my car, my replacement carb. is for a 69 400 4 speed car 7029253. Both our carbs. are much rarer than the 7029251.
Guy
Old August 22nd, 2013, 08:15 AM
morgan
pogo69's Avatar
Originally Posted by camshaw
I double checked my picture of the carb and the car # is 29254 RJ 0649........so is it a Rochester made by carter carbs on the 64th day of 69?
im thinking, not 100% sure though that it was the other way around the full 7029... was put together by carter and the 29... was direct from rochester
pogo69 is offline
Old August 22nd, 2013, 08:27 AM
  #31
carb.
That could be I don't know. But both are correct for the 69 H/O.
Guy
Old August 22nd, 2013, 08:53 AM
  #32
camshaw's Avatar
camshaw is offline
Old August 22nd, 2013, 08:57 AM
  #33
morgan
pogo69's Avatar
so the consensus is my carb isn't for a HO correct??
correct...carb is not for a 69 H/O.
pogo69 is offline
Old August 22nd, 2013, 09:01 AM
  #34
carb.
Just remember your carb. is much rarer than the right one. You should be able to get more $$$ for yours.
Guy
Old August 22nd, 2013, 09:49 AM
  #35
Octania's Avatar
Can you re-ck that carb?
in the pic above, I saw, and still see, "29251 RJ..."
I have seen a few '9254 carbs, but every one has always been
7029254
with none at all
29254
Whereas among the '9251 carbs I have seen, most by far were
7029251
with a few [like 2 or three seen anywhere, ever] with the shorter
29251
How do the dates line up?
I'd like to see the date codes from
Block
Heads
Intake
Water pump
exhaust manifolds
etc.
Octania is offline
Old August 22nd, 2013, 11:16 AM
  #36
camshaw's Avatar
camshaw is offline
Old August 22nd, 2013, 01:42 PM
  #37
rr69ho's Avatar
D/C for the heads is on the underside toward the intake.
The blocks julian date is next to the distributor on on pass side.
rr69ho is offline
Old August 24th, 2013, 09:13 AM
  #38
Cameo White's Avatar
That's a 29251 carb IMO. The picture makes the final 1 look a little funny. Not all the PN strikes on these things were perfect.
Cameo White is offline
Old August 24th, 2013, 10:04 AM
  #39
69HO43's Avatar
Cameo is correct. That's a correct carb for an H/O. And it being correct means it's actually more valuable to the package than a 254 carb would be, if that makes any sense. Cuz then u'd have to ditch the 254 and find a 251.
69HO43 is offline
Old August 24th, 2013, 10:55 AM
  #40
camshaw's Avatar
new carb pic
camshaw is offline
Quick Reply: h/o package parts deal
