Motor mounts
Old July 31st, 2023, 09:48 AM
alsmith787's Avatar
Motor mounts
Hello Guys -- need some advise have a '69 Hurst Olds 455 4v doing the oil pan & exhaust manifold change with engine not pulled just jacked (looks like it will work) I want to have motor & trans mount just in case. Where should I buy the mounts from I heard that these are replacement parts some work some don't meaning so cause vibration from OEM any suggestions I'd appreciate your guidance since I'm starting this week to work on it need your suggestions asap.
THanks for your help
alsmith787
alsmith787 is offline
Old July 31st, 2023, 12:09 PM
Unless you can find NOS 402950 mounts, anything else you buy will be the generic 2328-style mount. The aftermarket replacements were designed to be dimensionally correct but may or may not have the correct rubber hardness for NVH. The reality is that this is probably a second-order effect anyway.
joe_padavano is offline
user 83737473
October 27th, 2022 05:46 AM
joshduty
July 10th, 2022 04:30 PM
EsoWuhn
February 11th, 2020 06:04 PM
74 fastback
October 5th, 2015 05:29 PM
gabe442
Non-Olds Engines
December 1st, 2011 11:19 AM
Quick Reply: Motor mounts
