67 Cutlass/442 Accelerator Technical Information needed
Old March 18th, 2013, 06:26 PM
Flye's Avatar
I need some "technical help".
My 67 Cutlass/442 has an accelerator that attaches to the floorboard sheet metal of car (with two screws if I'm not mistaken) and pushes against a lever that has a little roller on it, and the lever then goes through the firewall, to a bell crank, to push/pull the throttle rod.
This is an automatic car.
Two questions:
-Did 67 Cutlass or 442 come with a 'hanging/suspended' accelerator that the accelerator is actually attached to the rod (i.e. not attached to the floorboard).
-Is there any difference between a 4 speed and automatic ACCELERATOR? (not the bell crank assembly, but the actual accelerator in the interior of the car)
Thanks for help. I've got a lot of people saying the 67 does not have a hanging accelerator and one person telling me they did.
Thanks,
Flye is offline
Old March 18th, 2013, 07:03 PM
Oldsmaniac's Avatar
No hanging pedal for 67, the stick cars did not have the switch on the firewall mounted linkage so there is a different on for manual trans. The floor mounted pedal is pushed on to ball mounts and just pulls off.
Oldsmaniac is offline
BeenThere
December 29th, 2013 07:21 AM
Intragration
November 26th, 2012 06:57 PM
synoptic12
July 2nd, 2012 10:20 AM
todd66442
August 1st, 2008 10:34 PM
todd66442
July 31st, 2008 03:51 PM
Quick Reply: 67 Cutlass/442 Accelerator Technical Information needed
