'68 442 / Instrument Cluster Bulbs
Old November 24th, 2020, 11:41 AM
Tom Bilse's Avatar
This is probably too easy, but I'd like to be certain.
I'm needing to replace my instrument cluster bulbs (speedometer, etc.)
The '68 Service Manual shows:
> bulb # 194 for "Instrument Cluster Lighting - Speedometer"
> bulb # 168 - 2-1/2 C.P. for "Instrument Cluster Lighting - Fuel Gauge & Tell Tale" (Rocket Rally Pac)
A photo of my gauges is attached.
Is bulb 194 used only for the speedo and bulb 168 used for the other two gauges? Or is 168 used for all three gauges?
Thanks.
Tom Bilse is offline
Old November 24th, 2020, 12:56 PM
72455's Avatar
Thanks.
They will all work...only difference is the wattage.
72455 is offline
Old November 24th, 2020, 02:03 PM
Tom Bilse's Avatar
Thanks for the quick response and help.
Old November 24th, 2020, 02:32 PM
Olds Fanatic
69 Hurst's Avatar
Hey Tom, hope you are doing well. I know I'm a '69 but...I'm using 194s in speedo & gauges, 168s in tach.
69 Hurst is offline
Old November 24th, 2020, 03:58 PM
Yellowstatue's Avatar
I think the owners manual & the CSM says #168 for a rally pack set up (all). #168 are brighter than #194.
Yellowstatue is offline
Old November 24th, 2020, 07:13 PM
Miles71's Avatar
My eyes are getting old.
On my 1969 442 I replaced all of my #194 bulbs with the brighter #168 bulbs [4.9 watts] at 38 Lumen.
Then I discovered the wedge #2825, 5.0 watts and 50 Lumen.
So I replaced all of my #168 bulbs in my 71 CS with wedge #2825.
The #2825 is plug in compatible with #194 and #168
FYI, You can't use LED bulbs on any Dimming circuits such as dash lights.
On my Cutlass supreme the Stock Idiot lights were the brighter #168 Bulbs and the Dimmable lights were the dimmer #194.
Now that they are all #2825, I can see the display much better.
Miles71 is offline
Old December 1st, 2020, 08:19 AM
Tom Bilse's Avatar
Thanks for the help. 2825's were installed yesterday. Learned the sockets for a couple of the gauges were brittle from age. Those were replaced also.
My future now looks much brighter.
Old December 1st, 2020, 04:04 PM
Olds Fanatic
69 Hurst's Avatar
I just ordered 2825's for mine.
69 Hurst is offline
Old December 2nd, 2020, 07:43 PM
70Post's Avatar
Where did you order "the wedge #2825's" from?
70Post is offline
Old December 3rd, 2020, 10:24 AM
Olds Fanatic
69 Hurst's Avatar
Try this. I also checked NAPA, they wanted almost $3 per bulb!!
Amazon Amazon
69 Hurst is offline
Old December 3rd, 2020, 07:50 PM
70Post's Avatar
Thanks and yes, I checked for some other bulbs at a local NAPA awhile back and they wanted some $ for sure....I guess it's the "convenience" factor there.
70Post is offline
Old December 3rd, 2020, 07:56 PM
mrolds69's Avatar
Patton, you have to be careful with those bulbs, more watts means more heat. They are ok in most aps, but like your GS heater panel, not so much. Because the housing is plastic and warps from the right size bulb. They do cost more, but all the auto chains have them.
mrolds69 is offline
Old December 3rd, 2020, 09:07 PM
OLDSter Ralph's Avatar
RockAuto has them for $0.16 each in 2 packs.......Hella brand H83220021 Seems to be several brands on the market and prices vary. Sylvania "Long Life" seem to be the most expensive.
OLDSter Ralph is offline
Old December 4th, 2020, 06:49 AM
mrolds69's Avatar
The problem with LL bulbs Ralph, is they are not as bright because they have a thicker filament. That's why they're long life!
mrolds69 is offline
Old December 5th, 2020, 08:43 AM
Bryan Burch's Avatar
these LED's look amazing in my 69
Amazon Amazon
Bryan Burch is offline
Old December 5th, 2020, 12:23 PM
Tom Bilse's Avatar
Photo (poor quality - apologies, but gets the point across I think) of speedo with 2825:
Old December 6th, 2020, 01:28 PM
Olds Fanatic
69 Hurst's Avatar
Big difference!! Can't wait to get mine in.
69 Hurst is offline
Old December 7th, 2020, 06:57 AM
Frankenstein 442 owner
ThaDeuce's Avatar
Originally Posted by tom bilse
photo (poor quality - apologies, but gets the point across i think) of speedo with 2825:
ThaDeuce is offline
Old December 8th, 2020, 01:31 PM
Olds Fanatic
69 Hurst's Avatar
Installed the 2825's...I can see my gauges!!
69 Hurst is offline
Old December 8th, 2020, 02:54 PM
ThaDeuce's Avatar
21 cents a piece plus shipping!
https://www.jacksonelectricsupply.co...AaAr85EALw_wcB
ThaDeuce is offline
Old December 9th, 2020, 04:38 AM
allyolds68's Avatar
Thanks for everyone's input into this thread I've been thinking about doing something for a long time because mine are so dim. FWIW I went looking to try and see how many bulbs there are in a 68-69 dash and I came up with 14. If anyone needs bulbs I'll be getting 35 from Jackson as that's the minimum order. It was still $7 less than 20 bulbs would have cost with Amazon Prime.
allyolds68 is offline
Old December 9th, 2020, 05:27 AM
ThaDeuce's Avatar
25 bulbs, $11.65 including shipping...
ThaDeuce is offline
Old December 9th, 2020, 05:40 AM
allyolds68's Avatar
I'm not sure why but when I tried to put 20 bulbs into the cart it automatically changed the qty to 35. I tried to change it three times. Finally I just bought 35. My total was $13.34 shipped (slow boat from china shipping, I was in no rush). My guess is I should have completely exited the page and re-entered the qty instead of hitting the back button to change it
Old December 9th, 2020, 05:52 AM
ThaDeuce's Avatar
I am using Safari browser, but did not have same experience.
I can also wait a week, this is a deep winter project anyway and we haven’t had our first snow yet.
ThaDeuce is offline
Old February 27th, 2021, 11:33 AM
1968.442's Avatar
Cluster removal and lighting problems
I changed all my bulbs out last night with 194 bulbs and only my tach and clock light up and very dim at that have to shut the lights off in the garage damn near to see i replaced my headlight switch a few days ago and really would like all my lights to work any ideas on what my problem is and if its easier to pull the cluster to fix and how to do that?
1968.442 is offline
goatwgn
August 16th, 2022 04:30 AM
rhett838
April 28th, 2016 10:14 AM
kansjfr
December 7th, 2014 05:10 PM
Redog
September 4th, 2013 08:42 PM
Quick Reply: '68 442 / Instrument Cluster Bulbs
