69-72 bucket seat headrest installation ??????
Old April 21st, 2008, 02:43 PM
twentyways's Avatar
I Have a set of 69-72 buckets for my cutlass the person i got them from had them re covered without the headrests when i took the old seat covers off i found that the top of the seat frame had the holes in the frame for headrest but on two of the headrest holes were plastic parts that were screwed into the frame. It looks like the headrests go in the lock assembly then into these plastic assemblies which would be underneath the cover. My problem is i only have two of these and the other two are missing. I would like to know what they are called and where i can find them or have them fabricated? I am in Ferndale Mi.
twentyways is offline
Old April 24th, 2008, 10:42 PM
2blu442's Avatar
Headrests
There should have been parts in the seat back for the headrest rods to go down into. Then the locks for adjusting the headrests should have been attached to the top of the seat, on the outside of the seat cover. I believe Year One make reproduction adjustment locks if that's what your needing. John
2blu442 is online now
Old April 24th, 2008, 11:26 PM
twentyways's Avatar
What do the lock assemblies screw into? Do they screw directly into the top of the frame? Do they screw directly into the metal? or like i said when i took off the old covers there were some plastic sleeves over the frame or was that something the guy did? If there is a part under the seat cover attached to the seat back frame where the lock assemblies screw into, I need the name or where that part is purchased or reproduced.
Old May 3rd, 2008, 08:08 AM
Registered
Bluevista's Avatar
Are these what you're looking for? http://cgi.ebay.com/ebaymotors/69-70...spagenameZWDVW
Allan
Bluevista is offline
Old May 3rd, 2008, 07:38 PM
2blu442's Avatar
Headrest Mounting Parts for a Bucket Seat
OK, I took a set of core bucket seats and took a series of photos of what's under the headrest. I cut the vinyl and it exposed something similar to what Allen posted, except the ones on ebay are probably for a bench seat with the flat metal slider rather than the two rods like the buckets have. The screws that go through the plastic and I believe eventually thread into the metal frame are long, and I took a picture of one almost unscrewed. I would hope your seats have this plastic piece but you'll still need to come up with the screws and the release that attaches on top of the cover. I'm sure I've seen these reproduction, but not sure where. Check out the following photos:
http://i90.photobucket.com/albums/k2...P1010518-1.jpg
http://i90.photobucket.com/albums/k2...P1010519-1.jpg
http://i90.photobucket.com/albums/k2...P1010520-1.jpg
http://i90.photobucket.com/albums/k2...P1010521-1.jpg
http://i90.photobucket.com/albums/k2...P1010522-1.jpg
http://i90.photobucket.com/albums/k2...2/P1010523.jpg
http://i90.photobucket.com/albums/k2...P1010524-1.jpg
http://i90.photobucket.com/albums/k2...2/P1010525.jpg
http://i90.photobucket.com/albums/k2...2/P1010526.jpg
Let me know if you have trouble viewing the photos or any other questions from them. John
88hurstolds
July 9th, 2012 01:21 PM
507OLDS
June 20th, 2012 11:42 AM
69442
December 28th, 2010 10:03 AM
crazy'boutOlds
May 23rd, 2010 05:36 AM
hinz57
October 8th, 2009 07:09 AM
Quick Reply: 69-72 bucket seat headrest installation ??????
