'71 Supreme Door Panel Carpet
Old March 6th, 2024, 03:27 PM
Macadoo's Avatar
Hey folks,
I bought new carpet from Fusick for my door panels. I haven't had a chance to mess with it yet but I'm wondering if anyone has some tips. I don't want to damage the panels, seeing as they cost more than $400 these days.
Just pop off the chrome trim, pull the old carpet off, maybe sand and smooth a little, then use contact cement for the new?
Help appreciated.
Macadoo is offline
Old March 6th, 2024, 05:41 PM
PatL's Avatar
Originally Posted by Macadoo
Hey folks,
Help appreciated.
Pretty much. I did it once; just be careful and slow, it is glued to cardboard. A sharp knive, like a carpet knive will help seperate.
PatL is offline
Old March 7th, 2024, 04:22 PM
No it's not a parts car!!
Schne442's Avatar
I replaced mine a couple years ago.
I used some card stock to fill the old speaker holes and to re-enforce the lower section
Schne442 is offline
Old March 7th, 2024, 04:45 PM
Originally Posted by Schne442
I replaced mine a couple years ago. I used some card stock.
Gary - Nice work. Essentially I did same. I was replacing the driver side 4-way power window switch which quickly became a MAW for both doors.
Vintage Chief is online now
Old March 7th, 2024, 06:08 PM
Macadoo's Avatar
Those look great! And pictures definitely help, thanks guys. Hoping the carpet arrives soon.
Macadoo is offline
Old March 10th, 2024, 07:34 AM
Macadoo's Avatar
Okay folks, so I got the carpet from Fusick in three days, not bad! Everything seems pretty straight forward, other than keeping the shop warm enough for the contact cement, but I'm not real worried.
However, a MAW got ahold of me Since I had the door panel off anyway, I thought I'd give the window mechanism a little grease (even though I haven't had any problems). What's the old saying? If it ain't broke? Now the window moans and screeches on it's way up and down. So I cleaned off all the old and new gunk with brake cleaner and no change, still moans and screeches. I used a silicone grease first. Cleaned that off and used regular ol' wheel bearing grease, cleaned that off and now I'm thinking of using that green brake caliper grease. The noise seems to be coming from the vertical conduit-looking rod down the middle of the cavity. Thoughts?
Macadoo is offline
rocketcouple
May 16th, 2019 01:18 PM
cublex
September 29th, 2016 12:12 PM
White_Knuckles
May 3rd, 2013 07:12 PM
defiant1
April 30th, 2012 07:53 AM
yeahbuddy
April 4th, 2010 11:05 AM
Quick Reply: '71 Supreme Door Panel Carpet
