Advice on glue needed- vinyl to hard plastic
Old April 7th, 2024, 05:46 AM
BlueCalais79's Avatar
Quick question on what glue to use for:
1994 Cutlass Supreme convertible, rear seat back in between the 2 bucket seats. This is the car I'm selling, I just found the vinyl piece that needs to go back on that plastic "trap door" piece on the seat back. This is the hinged piece right behind the console, which when opened you can peer into the convertible's trunk and/or the top motor.
I'm loathe to use spray adhesive but I will if nothing else works,
Any help would be appreciated. I need to get this piece back on securely, as it's really the only ugly thing about this otherwise really nice interior.
BlueCalais79 is offline
Old April 7th, 2024, 05:52 AM
Contact cement is what I'd use.
Olds64 is offline
Old April 7th, 2024, 07:30 AM
Thanks, that comes with its own brush/applicator, I'll give that a try
Old April 7th, 2024, 07:57 AM
Tedd Thompson's Avatar
I've used Shoe Goop on like problems, a little slower drying but is flexible for the vinyl, sticks to any plastic I've tried it on, tougher than contact glue..Tedd
Tedd Thompson is offline
Old April 7th, 2024, 08:26 AM
Thanx Ted! Looking for this to be a one and done, I'm looking to get this car sold.
Old April 7th, 2024, 09:34 AM
Shoo Goo is a great suggestion. I have used it on many things not shoe related and it worked exceptionally well. I like it so much I make sure there’s always some on hand.
Fun71 is offline
Old April 7th, 2024, 10:47 AM
Most use Weldwood Landau top and trim adhesive.
oldcutlass is offline
Old April 7th, 2024, 04:10 PM
Sounds messy...
Vintage Chief is offline
Old April 7th, 2024, 04:16 PM
Sure is, and for a piece that never should have been there in the first place. Even if the top motor went bad, it won't fit through that hole very easily if at all without making a total mess. Should have just been all dyed as a one piece.
Old April 7th, 2024, 08:19 PM
Sounds messy...
Peeling that stuff off fingers takes a long time. It’s worse than super glue.
Fun71 is offline
Old April 8th, 2024, 07:19 AM
garys 68&72's Avatar
Most coctact adhesive will come loose from the heat (3M super 77, etc). The lanau roof glue is better, 3M trim adhesive and 3M 1357 will hold great. PVC cement works on most vinyl/plastics too.
garys 68&72 is offline
Old April 9th, 2024, 05:34 AM
Thanx to one and all, I'm going to roll with the Weldwood and do a one and done.
Old April 9th, 2024, 05:42 AM
Let us know how it works and make sure you post some pics.
Olds64 is offline
Old April 21st, 2024, 05:25 AM
Got my can of Weldwood, will advise on how this all turns out. I wonder how this stuff would work on adhering the hood insulation to the hood, there's one nagging spot where the clips to not hold it and there is about a 6 inch area on the front part which sags.
epinkston
Body work
April 28th, 2019 08:06 AM
unfoldthesoul
April 16th, 2017 05:01 PM
67442nut
August 6th, 2014 11:26 PM
rootney
June 20th, 2013 04:32 PM
70Post
March 16th, 2011 07:21 PM
Quick Reply: Advice on glue needed- vinyl to hard plastic
