Delta 88 - 1966 - Cowl Tag - Color codes
Old July 31st, 2014, 03:08 PM
DKLeader's Avatar
Hi,
I am the happy owner of a Delta 88 from 66 and would like to replace the carpet, but cannot seem to get the color code translated.
From my cowl tag I already know that
66 = 1966
3 = Oldsmobile
58 = Delta 88 V8 (1965-1967)
67 = 2d convertible
C2 = Provincial White
But I cannot seem to find out what color trim 918 is and what 05A is.
From searching the net I could believe it would be burnt orange (21), but would like to be sure before ordering and having it sent to Denmark.
Hope someone can help on this one
Best regards
Jakob
DKLeader is offline
Old July 31st, 2014, 03:52 PM
05A is the time build code from when Linden (Fisher Body Works) started building your car from sheet metal parts. It breaks down to the first week (A) of May (05) 1966.
Trim Code 918 is Medium Bronze
Allan R is offline
Old August 1st, 2014, 10:49 AM
chrisneu68olds's Avatar
Here is my output:
chrisneu68olds is offline
Old August 1st, 2014, 11:16 AM
Jakob,
May I suggest you also invest in a 1966 Oldsmobile Chassis Service Manual? (Also known as CSM) This is a valuable source of info for your car. There is also an Assembly Manual for the B/C (your body style) cars available. These sources also include the paint codes from the paint manufacturers for the colors on your car.
Chris - how did you determine Bronze Vinyl trim? I can't find that reference in the Assembly manual? Just code 918 and the color. I looked at the pics of the 66 Delta Dealer brochure and they say the trim is a combination of Morocceen Vinyl with cloth inserts for the seating area. Probably the same thing as your reference?
Allan R is offline
Old August 1st, 2014, 11:54 AM
I might be reading this incorrectly but it says "First digit denotes material - 1-All Vinyl."
Old August 1st, 2014, 12:11 PM
Oldsdruid
rocketraider's Avatar
To my knowledge bronze interior was available only in vinyl, and recommended only with Autumn Bronze, Provincial While, and Ebony Black paint. It would probably have worked pretty well with Sierra Mist, Almond Beige, Target Red and Burgundy Mist.
rocketraider is online now
Old August 1st, 2014, 03:26 PM
DKLeader's Avatar
Thanks for all the replies, but still seems a bit confusing on what color the carpet. Searching for bronze does not come up with any match for Delta 88 1966
Allan : I already have that one and "1966 BODY BY FISHER SERVICE MANUAL", but they do not mention that color code. Have them as hard copy and pdf.
DKLeader is offline
Old August 1st, 2014, 05:16 PM
Nope, I read it the same way, after I looked it up in the 66 SPECS. Good catch and thank you for the info.
Allan R is offline
Old August 1st, 2014, 05:32 PM
Looking in SPECS and other docs, I don't see anything specified for carpet color. I suppose the question is; do you have carpet in there now?
Old August 4th, 2014, 03:14 AM
DKLeader's Avatar
chrisneu68olds yes I do have a carpet in the car. And it matches the color of the seats. From the wear of it I would assume it being the original.
Best Regards
Jakob
DKLeader is offline
ithaca4me
August 1st, 2023 03:39 PM
Tadpole11
August 6th, 2014 06:34 PM
arodenhiser
September 3rd, 2010 06:33 AM
crzyjef
July 17th, 2010 05:17 AM
Mr. King
January 14th, 2007 07:47 PM
Quick Reply: Delta 88 - 1966 - Cowl Tag - Color codes
