My seat belt tensioner is stuck!
Old February 9th, 2014, 07:46 PM
plonka's Avatar
Anyone know how to fix a stuck front seat belt tensioner? If I remove the plastic cover over the tensioner, there's a little lock release pin which when pressed, it allows you to pull the belt out. I'm looking for a proper fix. I can't pull any of the belt out otherwise. Thanks in advance.
plonka is offline
Old February 9th, 2014, 11:33 PM
'87 Delta 88 Royale
rustyroger's Avatar
Has the belt moved on its mounting?, that will cause it to lock.
For the price of a new belt I'd simply replace it.
Roger.
rustyroger is offline
Old February 10th, 2014, 08:15 AM
plonka's Avatar
The belt has not moved to my knowledge and the car is parked on level ground.
plonka is offline
GSX012
June 16th, 2015 03:33 PM
Rocketbrian
January 20th, 2015 06:59 AM
slayed
May 8th, 2013 08:10 PM
kbdecatur
June 15th, 2012 04:19 PM
Olds98
August 6th, 2010 05:02 AM
Quick Reply: My seat belt tensioner is stuck!
