Replacement door pins and bushings
Old November 11th, 2008, 11:15 AM
ChrisM's Avatar
Question Replacement door pins and bushings
Hello all,
I am all ready to replace the door hinge pins on my '73 Delta 88 with a pin and bushing kit from the parts store, but as I stand looking at the door with the kit in my hand I am having a few questions:
1. how do I get the old pins out? they have a clip on holding them in place that looks to be part of the pin.
2. How do I get the new bushings on? I can't see any bushings on the old pins. Am I just not seeing the old bushings, or am I going to have to drill out or reem out the old pin hole to accomodate the new bushings?
Any help would be greatly appreciated. I looked in the shop manual, but it doesn't give any real insight, so I was hoping to get some help and possibly a step by step proceedure for fixing my sagging doors.
Thank you all in advance,
Chris
ChrisM is offline
Old November 11th, 2008, 11:37 AM
All you should have to do is remove the clips holding the pins in the hinges. Then knock out the pins with a small hammer while a buddy holds the door. After the door is removed you should be able to insert the bushings into the hinge without any trouble. Assemble in reverse order.
Olds64 is offline
Old November 16th, 2008, 05:34 PM
dharlett's Avatar
hinge pin replacement
Chris,
Here's a link to a site that might be helpful. They detail how to replace the hinge pins in a 70 Chevelle.
http://www.route66restorations.com/hingepins.html
Best of luck,
Dan
dharlett is offline
Niko
April 22nd, 2013 06:40 PM
boondocker
Body work
October 18th, 2011 05:32 AM
Ddbord
July 13th, 2010 05:39 AM
dyscookn
February 16th, 2007 12:24 PM
polcatt
October 8th, 2006 07:03 PM
Quick Reply: Replacement door pins and bushings
