Tick-Tock-Tach
Old March 29th, 2007, 11:36 AM
442buyer's Avatar
Tick-Tock-Tach
Did all 1968 442's come equipped standard with a tick-tock-tach, or was it an option?
442buyer is offline
Old March 29th, 2007, 12:25 PM
70Wcars's Avatar
Rallye Pack gauges including the tick-tock Tach were options.
70Wcars is offline
Old March 29th, 2007, 12:41 PM
442buyer's Avatar
Appreciate that. Can you tell me what other gauges were included in the Rallye Pack?
Any key questions you would ask as a buyer of a 68 442?
442buyer is offline
Old March 30th, 2007, 06:41 AM
2blu442's Avatar
The far right pod had a tac and clock combined in it, the far left pod has gauges rather than idiot lights for oil pressure, water temp and I think volts, I know it has three items in it. Look to see if it's number matching or not, start with the vin to see if it's a real 442 or Cutlass with badges added. Numbers matching bring more money. Look for rust in the common places, behind both front and rear tires in the body. If it's had a vinyl top, check for rust around the front and rear windshields. Under the battery box is another common place for the core support to rust out. Consider options on the car, typically that adds value to the car. Crawl over it and post questions about anything your not sure about. Good Luck! John
2blu442 is offline
Old March 30th, 2007, 06:43 AM
442buyer's Avatar
Thanks very much. Appreciate the detail.
442buyer is offline
Old January 6th, 2012, 11:56 PM
tcarroll's Avatar
The gauge on the far left had fuel in the upper center and then water temp and oil pressure on either side of it. There was no voltmeter in this gauge.
tcarroll is offline
Old January 7th, 2012, 06:43 PM
Randy C.
rcorrigan5's Avatar
Kind of hard to see but here's a picture.
Randy C.
rcorrigan5 is offline
akins2000
April 22nd, 2014 02:48 PM
Koda
December 3rd, 2013 08:50 PM
455 Olds 442
May 9th, 2013 03:05 AM
72442
September 23rd, 2009 08:43 AM
442buyer
March 31st, 2007 06:46 AM
Quick Reply: Tick-Tock-Tach
