1956 Oldsmobile Super 88
Old February 15th, 2021, 08:16 PM
Ihatefiberglass's Avatar
It's probably about time I stop posting in every corner of these forums and keep everything centralized. Here is my 1956 Oldsmobile Super 88 project. I have the body and frame stripped down. The frame was recently powder coated and came out really nice. The engine an tranny are rebuilt. Currently I'm working on rebuilding the rear end.
As you can see via the pictures below, there was some body work done to this car in the 70's with roofing tar and flashing. Also there are pictures of the very back of the body where the body mounts to the frame. Currently I have the frame on a rotisserie as you can see. Where the body mounts to the rotisserie is completely rusted through.
I have been searching for parts but I can't find the body panels; including junkyards, that would have rear wheel wells for this car. I also am looking for that piece of metal in the rear where the body is completely rusted through. It looks like square tubing in the back where the rotisserie is mounted to. My gut feeling is I'll have to hire a metal fabricator to weld new metal in.
Ihatefiberglass is offline
Old February 16th, 2021, 10:05 AM
What color is your paint code?
I am going to repaint the car with Alcan White on top, and a light blue on the bottom. If anyone has a car painted with light blue, could you please post a picture with the color code for the blue paint? I can find the color codes but before I commit to a color I want to see how it looks on the car in the sun.
Old February 18th, 2021, 04:04 PM
Tedd Thompson's Avatar
Do you have a picture of the light blue? It looks like there was 4 blues and I don't have a color chart but I do have the Dupont # color codes.
43 Frost Blue...#1594
42 Bimini Blue...#2007
41 Panama Blue...#1989
40 Twilight Blur...#1992
Tedd Thompson is offline
Old February 19th, 2021, 03:31 PM
Frank Ignachuck
ignachuck's Avatar
Google is our friend. I would suggest you google "1956 Oldsmobile Exterior Paint" and look at the various charts. Caution: some are actual paint charts and some are pictures of paint charts, which may not be all that accurate.
ignachuck is offline
Old February 19th, 2021, 04:41 PM
2blu442's Avatar
I've got a message out to the guy I know with 1956 parts. I do have some sheetmetal from 1954 and 55 if any of these areas interchange. Attached are a couple photos. The loose trunk floor is from a 1954 Olds 88 2 door hardtop. Then the blue car is a 1955 Olds 98 4 door post car. If any of this fit it would be available. John
2blu442 is offline
Old February 20th, 2021, 10:05 AM
After much research I think I'm going to go with the following colors
Alcan White - Ditzler PPG 8123; Dupont 2264, 246-59604
Turquoise - Ditzler PPG 11132; Dupont 1693, 202-57610.
My image for the car is this color scheme:
I realize that's a '55 (I think) but I really the colors.
Old February 20th, 2021, 10:11 AM
Yes you are correct, google is probably one of our best resources. You are also right about the paint charts. In addition I have found whenever I type in a particular color and look at images they are often mislabeled and I'll see like 5 obviously different shades of blue. That's why I was hoping some people with blue Olds could tell me exactly what color their blue was because there would be no ambiguity regarding the color code.
Old February 20th, 2021, 10:12 AM
Hey John, thanks for reaching out to that guy for me, he has contacted me.
Old February 20th, 2021, 10:14 AM
Also, I'm very interested in that trunk pan you have and quite possibly those wheel wells too. I need to finish getting the tar and flashing out of my trunk so I can see how bad the damage is. I'll send you a PM.
Old February 20th, 2021, 11:30 AM
Proud Viet Nam Veteran
redoldsman's Avatar
In a PM you had requested info on the blue on my car which is Capri Blue which is an original 54 color. The car had been repainted twice prior to my ownership but was originally solid Capri Blue. You also requested a couple photos taken in the sunlight. I will post 2 or 3 below.
redoldsman is online now
Old February 20th, 2021, 12:41 PM
Both those colors look really sharp. Thanks for posting. I think I like the glacier white better than the alcan white. I realize right now it's probably really silly to worry about colors; but I am working with an upholstery shop as well and I'm trying to get a spray out from the body shop so I can give that to the upholstery shop to get them going. Then while the upholstery shop is doing their thing, I can work on the body until the body shop is ready to accept my car.
Old February 20th, 2021, 03:09 PM
Frank Ignachuck
ignachuck's Avatar
Glenn, cut it out! You're killing me with those pictures of your car!!!
Old February 20th, 2021, 05:29 PM
redoldsman's Avatar
It is the P51 in the background that makes the car look good.
Old February 22nd, 2021, 04:34 PM
Originally Posted by Ihatefiberglass
I recently ordered this brake booster rebuild from Fusick for my Treadle-vac. As you can see there's several discrepancies between the pistons. The new piston is shorter, does not have a groove for an o-ring on the end, and does not have that pushrod thing going down the center. Is this a new and improved design? I called Fusick as well, maybe they can figure it out. Thanks for all your help over the years guys, you are an invaluable source of knowledge and information.
Old February 22nd, 2021, 04:35 PM
Fusick got back to me. They spoke to their guy who rebuilds these things and the piston included in the kit is an improved design.
Old February 23rd, 2021, 06:47 PM
...And the grinding begins
Old February 23rd, 2021, 06:49 PM
Old February 23rd, 2021, 06:52 PM
Below are two carrier races for the diff. The one on the left is the old one with a groove, the one on the right is the new one. Do the races need to have that grove in there for oil or something to flow?
Old February 24th, 2021, 08:18 AM
rfpowerdude's Avatar
Can't wait to see this car finished and in person! Considering I work in Indialantic and live in Palm Bay, I'm sure we will cross paths eventually...
rfpowerdude is offline
Old February 24th, 2021, 11:18 AM
Oh yeah, you'll see it, I'm gonna drive it quite a bit. I'm not spending 60k and years of my time to have a trailer queen.
Old February 24th, 2021, 08:22 PM
I'm about half way done stripping the undercoating off from the bottom of the body. I think this has been my least favorite job so far.
Old February 24th, 2021, 08:48 PM
Kemmons's Avatar
Parts
Need any parts I probably have them. Not only do I have what’s seen in these pictures but I have shelves full of parts for the 1956 that never got restored that was purchased in between 1976-1978 and have been in the garage ever since.
Kemmons is offline
Old February 25th, 2021, 05:52 AM
PM Sent
Old February 26th, 2021, 08:11 PM
and grinding...and grinding...and grinding... I wont be the least upset when this part is over. I think the last of the crappy grinding I have to do includes the front and back wheel wells and fenders.
Old March 4th, 2021, 09:07 PM
I got the rear end back this evening. New leaf springs came in from Fusick last week. Also as you can see I had the suspension parts powder coated. Just need to clean up the drums and I'm ready to build a rolling chassis.
Old March 4th, 2021, 09:10 PM
I removed most of the aluminum flashing from the rear wheel wells. It looks like the body work rabbit hole is only going to get deeper.
Old March 6th, 2021, 08:11 AM
Old March 6th, 2021, 08:12 AM
I'm thinking about powder coating my brake drums, would it be a bad idea to do this? What is your experience? I see a lot of mixed reviews on the subject.
Old March 10th, 2021, 07:41 PM
Old March 20th, 2021, 02:36 PM
It's kinda nice to put things together that aren't complete greasy or rusted. It looks like I'll need to get some weight on that frame to compress those springs before I can connect the rear shocks and stabilizer bar.
Old March 20th, 2021, 02:43 PM
  #31
chopolds's Avatar
I used a heavy ratcheting tie strap to pull the rear up so I could attach shocks and sway bar.
chopolds is offline
Old March 21st, 2021, 07:28 AM
  #32
Did you release the ratchet strap after connecting the shocks and sway bar? Or did you drop the body back on first?
Old March 21st, 2021, 04:47 PM
  #33
chopolds's Avatar
The body is still not on, just released the strap and let the shocks hold it in place.
chopolds is offline
Old March 22nd, 2021, 03:19 AM
  #34
Great job!
Greg Rogers is online now
Old March 22nd, 2021, 08:34 PM
  #35
That wouldn't damage the shocks having that kind of pulling force on it for a prolonged period of time?
Old March 23rd, 2021, 10:27 AM
  #36
Great job!
Thanks, it's been quite a process.
Old March 24th, 2021, 11:42 AM
  #37
fredb_'s Avatar
You're doing a nice job on it. I don't have the ambition currently to tear mine apart, but enjoying driving it anyway.
fredb_ is offline
Old March 26th, 2021, 12:51 PM
  #38
Thanks. I don't blame you. it's slowly shifting from being fun to imitating a full time job. I'm trying to stay enthusiastic but it's difficult. I've got about 20k sank into it now, I guess I'm in it to win it.
Old March 29th, 2021, 06:24 AM
  #39
fredb_'s Avatar
It’s easy to get more invested than you want to. I restored a 38 Ford about 10 years ago and at times got a little discouraged, but was glad to get it back on the road where it could be enjoyed.
fredb_ is offline
Old March 29th, 2021, 06:58 AM
  #40
That is a fine looking Ford!
Quick Reply: 1956 Oldsmobile Super 88
