1970 442 W-30 convertible
Old July 8th, 2014, 10:00 AM
  #161
Lance
ROCKET VAPOR's Avatar
Originally Posted by bennie442s
what bolt or is there a bolt that is supposed to hold the grills together?
A large Phillips pan head self tapping screw is used to hold the original grills together. This same Phillips pan head screw is used to fasten the grills to the plastic head light extensions.
FWIW, I have been told that this style of screw will not work with the reproduction grills.
ROCKET VAPOR is offline
Old July 8th, 2014, 03:18 PM
  #162
bennie442s's Avatar
thanks
Thanks guys for the help with the information for the pan head screw, the grills are NOS, so the pan head screw should work. What is the correct finish of the pan head screw?
bennie442s is offline
Old July 8th, 2014, 04:56 PM
  #163
Lance
All three of mine were phosphate plated from a March of 1970 production, built at the Fremont plant.
FWIW, I believe INT sells these screws in a bright shiny clear zinc plating.
Old July 8th, 2014, 05:38 PM
  #164
Shoveling Snow
Hairy Olds's Avatar
The philips head screw with the sheet metal threads is correct. Patton would know.
Hairy Olds is online now
Old August 5th, 2015, 08:34 PM
  #165
bennie442s's Avatar
13 months since last reply...time flys!
So it has been a while since my last post....about 13 months! Not much has been done to the car since all the paint and body were finished. I sent the alternator off to Patton for restoration and it seems to be quite the project, about a million cracks. However, it seems as if it has welded up nicely. Here are a few pics to appreciate the sheer amount of time. Cannot wait to see the finished product!
Power Steering pump and starter are next.....then it will be time to tackle the wiring harness!
Old August 5th, 2015, 09:52 PM
  #166
bennie442s's Avatar
more pics
almost finished.
Old August 6th, 2015, 07:55 PM
  #167
NDERISE's Avatar
Thumbs up great save
looks very good to me great save on a very rare component and original to your car. your car looks great and what a great store behind the car. keep it in the family.
NDERISE is offline
Old August 17th, 2015, 12:13 PM
  #168
bennie442s's Avatar
pics of the the body completed
First photo is of my taking it home last July and the other two are pics of the car sitting in the garage. Slowly but surely I am getting back to this project. Installing the wiring harness is next, I just need to decide which company I am going with. Need to get going with the power steering pump, starter, and the dual gate shifter. Those items need to be sent out for restoration. Interior and Top will follow after that.
Old November 18th, 2021, 05:37 PM
  #169
bennie442s's Avatar
First time /long time
First post in a loonnngggg time on my project. I finished two Vista Cruiser builds while I was searching and gathering up more parts for my 70. Here are a few pictures to start the update.
Dash is in along with new wiring harness.
70 California Emissions Carbon Canister Valve restored.
A/C system restored and being installed.
Old November 18th, 2021, 05:39 PM
  #170
bennie442s's Avatar
Old November 19th, 2021, 03:14 AM
  #171
scrappie's Avatar
It has been a while. Welcome back!
scrappie is offline
Old November 22nd, 2021, 06:09 PM
  #172
bennie442s's Avatar
SS1 wheel restoration has begun.
W
Used 0000 steel wool to clean up the spokes and prepare for masking.
Painters tape and an razor blade to protect the spokes
Working on SS1 wheels. Brighten up the spokes with some steel wool and will then clean up the rest of the rim. Centers to be painted flat black and the rest of the rim in a semi gloss.
Old August 1st, 2022, 07:25 PM
  #173
bennie442s's Avatar
Progress Continues
Suspension bolts in the rear tightened and torqued. (Done on a 4 post lift, with weight on the car). Original to the car driveshaft blasted, primed, filled, sanded and balanced. Original drive shaft stripes located and recreated.
Working on finalizing a few underbody details. Checking all suspension and steering bolts in the front.
Old August 29th, 2022, 06:07 PM
  #174
bennie442s's Avatar
Upholstery in progress!
Getting ready to load up into the trailer to go to Upholstery. First time out in the sun since taking it home from body and paint!
Convertible Top frame goes up and down, no issues. First time the frame has been up since 2012!
Seat frames blasted and looking good! Springs will be rebuilt and clips redone. Project moving along!
Rear seat frame will need a little more work than the front. Springs a little weaker. Should go back together nicely!
Old September 12th, 2022, 06:27 PM
  #175
bennie442s's Avatar
Inching towards the finish line
The car continues to make progress in Upohlstery. The header bow fought us for awhile, but the car looks great with the top on. First time in a decade since the car had a top on it!
Un-obtainium acquired! 3 Way Tee for the California NA9 emissions system. GM NOS!
Old October 22nd, 2022, 02:59 PM
  #176
bennie442s's Avatar
Upholstery Pictures
Windshield and trim is in.
Old October 23rd, 2022, 07:33 AM
  #177
BackInTheGame's Avatar
Total Awesomeness! I love to watch these journeys!!
BackInTheGame is offline
Old October 30th, 2022, 06:37 PM
  #178
bennie442s's Avatar
Car is back home!
Old October 31st, 2022, 07:35 AM
  #179
Escape From The Ordinary
WTHIRTY1's Avatar
You're doing a very nice job on the resto of this W-30. Final stretch!
WTHIRTY1 is offline
Old October 31st, 2022, 04:02 PM
  #180
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
That paint doesnt suck!
droldsmorland is offline
Old October 31st, 2022, 04:45 PM
  #181
No lie. Car is looking great.
no1oldsfan is offline
Old November 13th, 2022, 03:26 PM
  #182
bennie442s's Avatar
NA9 California Carbon Emissions system hooked up with correct flat style spring clamps.
Elbow installed into air cleaner for the California 9AN system.
Trunk lid decals installed.
Engine compartment coming together. I’ve waited a long time to put the OAI air cleaner back on the car!
Old November 13th, 2022, 04:22 PM
  #183
Looking just great. 👍
I love white interior cars. There was a 70 SX near my house when I was a kid that was Rally Red with a white top and white interior. I bet you are super happy how it is turning out. Cool story. Cool car.
Old November 13th, 2022, 06:51 PM
  #184
Loaded68W34's Avatar
The car is looking great! Where did you get the OAI foam? It looks like it has the factory yellowish-green coloring unlike the black foam that most reproductions use.
Loaded68W34 is offline
Old November 13th, 2022, 08:35 PM
  #185
bennie442s's Avatar
OAI Foam
The OAI top and foam were purchased NOS about 12 years ago out of Virginia. I had to save my nickels for that one 😎.
Old November 14th, 2022, 02:47 AM
  #186
alain's Avatar
The car is looking AWESOME
Alain red W-31
alain is offline
Old November 14th, 2022, 06:32 AM
  #187
'70 4-Speed W Machine
tnswt's Avatar
Meticulous restoration, however I thought the washer jar cap on a ’70 car was plain and free of inscriptions?
tnswt is offline
Old November 14th, 2022, 01:34 PM
  #188
61Bat's Avatar
Just WOW.
Nice job sir. Great thread, thanks for sharing your journey.
61Bat is offline
Old November 16th, 2022, 08:05 AM
  #189
Eddie Hansen's Avatar
Breathtaking…..
Thank you for sharing, this has been an inspiring build, just read through with two cups of coffee great stuff and a beautiful car
Eddie Hansen is offline
Old November 16th, 2022, 08:15 AM
  #190
WTHIRTY1's Avatar
You'd be correct.
WTHIRTY1 is offline
Old November 16th, 2022, 10:26 AM
  #191
scrappie's Avatar
I dont know so I ask: What side should the bottle be on? Ive seen them on driver’s side also. Does ac make a difference? I’ve seen Original cars with no ac on the passenger side and this one has ac and its still on passenger side. Do they ever end up on driver’s side from the factory?
scrappie is offline
Old November 19th, 2022, 05:49 PM
  #192
bennie442s's Avatar
Photos from MCACN
Cannot say enough about the MCACN show. Lots of fun to show my car off next to some incredible cars.
Brought home from the hospital in 1982 in this W30.
The NOS front bumper just fits so well on my car!
Great group of judges to work with at MCACN 2022. Some easy tweaks and a few bigger ones, but on the right track with my car.
Learned a lot from the judges, work to do to correct the trunk compartment and areas of splatter paint. Underside reveals too much pitting on the differential. I’ll pull the differential out for a cosmetic makeover before next year.
Old November 19th, 2022, 07:22 PM
  #193
Good for you. Great job.
Old November 20th, 2022, 03:47 PM
  #194
bennie442s's Avatar
Mcacn award winner
First show and debut for my W30, it takes an award! MCACN Concours Silver!
Old November 21st, 2022, 07:25 AM
  #195
Well deserved!!!!
Well deserved!!!! That must be an awesome feeling seeing all your hard work pay off
Rocketguy
June 3rd, 2017 06:00 AM
Ken442
December 18th, 2014 08:20 PM
Giddy
February 17th, 2013 11:43 AM
dr77olds
January 4th, 2013 09:24 AM
grautogallery
January 28th, 2012 03:16 PM
Quick Reply: 1970 442 W-30 convertible
