'37 olds coupe build
Old August 11th, 2016, 12:02 PM
  #41
t23bucket's Avatar
check this website:
http://www.antiqueolds.org/advisors.html
the advisor for 1937's may have an answer...
t23bucket is offline
Old August 11th, 2016, 12:05 PM
  #42
t23bucket's Avatar
not too much new to report, got the radiator mounted. this weekend I plan on building the rear tubs & floor, building a battery box, and fuel cell mount. here's a pic of the radiator & cowling.
Old August 11th, 2016, 12:10 PM
  #43
t23bucket's Avatar
went to a swap meet last weekend, picked up a pair of street tires to replace the slicks currently on the car. they are nos, 33x12.50x15. they fit nice, and couldn't pass them up for $70.00.
Old August 11th, 2016, 12:28 PM
  #44
t23bucket's Avatar
got a little ahead of myself; didn't realize I skipped a few things.
I ended up buying a kit from speedwaymotors for the front suspension...I think it is very nice. speedway included the axle, springs, spindles, brakes, king pins, steering arms, tie rod, shackles, spring perches...just about everything.
I ordered it with a 4" drop; it was $799 shipped to my door. I cut & welded some 2x3 box tubing, and installed the axle kit. I was very happy to be able to finally roll it back & forth in the garage.
then I fabbed a mount for the Saginaw power steering box & tacked it in place. attached are a few pictures.
before winter, I'd like to have everything fabbed & tacked so I can pull the body off the frame, finish weld everything, and have the frame powdercoated. then, hopefully, over the winter I can bolt it all back together, wire/plumb it, and have it ready for spring.
Old August 11th, 2016, 03:08 PM
  #45
Eddie Hansen's Avatar
Really nice tbucket!!
Eddie Hansen is offline
Old August 11th, 2016, 03:42 PM
  #46
Coming along nicely.
oldcutlass is online now
Old August 15th, 2016, 09:10 AM
  #47
t23bucket's Avatar
Thanks eddie & eric.
built some basic framework out of 3/4 x 3/4 x 1/8 angle in the back of the car; next weekend I will build the tubs & rear floor. i'll post more pics soon.
Old September 6th, 2016, 01:25 PM
  #48
looking forward to seeing the progress Love this car!
Old September 6th, 2016, 01:58 PM
  #49
t23bucket's Avatar
so, my dad & I fabbed up some light framework for the rear of the car. we used 3/4 angle, and basically just built a simple 'box' for the rear tubs and floor to mount to.
after tacking the angle in, we measured & cut some 20 gauge steel, ran it through his beader/crimper, and tacked it in. then we cut out some of the old floor (that had rust issues) to make a tunnel for the driveshaft & driveshaft loop.
next weekend, we'll start on the recessed firewall/doghouse, front floor, and tin for the trans cover.
Old September 6th, 2016, 02:02 PM
  #50
t23bucket's Avatar
one last pic showing the rear tubs, tin, and start of the tunnel.
the fuel tank will mount behind the axle, between the frame rails.
it is being custom made, measures 26" wide x 11" deep x 16" long...should be just under 20 gallons. hopefully we'll have that mounted next weekend as well.
Old September 6th, 2016, 02:04 PM
  #51
t23bucket's Avatar
for some reason, pic did not attach on last message....
Old September 7th, 2016, 11:03 AM
  #52
sweet
nice work!!
Old September 7th, 2016, 02:10 PM
  #53
Once Olds Always Olds
Troys Toy 70's Avatar
Wow, don't know how I missed this one. Great work! I'm in.
Troys Toy 70 is online now
Old September 7th, 2016, 03:08 PM
  #54
t23bucket's Avatar
thanks, I was hoping to be a little farther by now, but between traveling for work & trying to balance time with my wife/son, I don't always make much progress.
I'm wondering if anyone can give me some advice. I didn't get a seat with the car & am wondering if anyone can suggest a seat that might work. either a bench or buckets would work I guess...but a bench would probably work better for the wife & kid. I can't seem to find an original seat, but am wondering if maybe one from a buick or Pontiac may work...I think they were basically the same body?
Old September 12th, 2016, 08:02 AM
  #55
t23bucket's Avatar
started on the front floor & trans tunnel.
framed in the edges with 3/4 angle, and started cutting the 20 gauge tin...my boy was quality control.
Old September 12th, 2016, 08:04 AM
  #56
t23bucket's Avatar
cut to fit, holes punched for welding, radiused & notched for trans tunnel.
Old September 12th, 2016, 08:06 AM
  #57
Maybe he'll take an interest, I got the affliction working with my dad when I was about his age.
Old September 12th, 2016, 08:08 AM
  #58
t23bucket's Avatar
tacked it in, then started on the trans tunnel.
the break & roller are at my dad's shop, so I had to bend it by hand...
Old September 12th, 2016, 08:10 AM
  #59
t23bucket's Avatar
I hope so...
Old September 12th, 2016, 08:15 AM
  #60
t23bucket's Avatar
made the rear driveshaft tunnel & welded it in.
it was a good day. next will be to finish the mount for the fuel tank, and cover the rear trunk floor & recessed firewall.
would like to finish all the fab work on the body so I can pull the frame out from under it, seal weld everything, and have the frame powdercoated before winter.
Old September 13th, 2016, 11:10 AM
  #61
looking good!!
Old September 21st, 2016, 05:29 AM
  #62
t23bucket's Avatar
not much progress to look at.
I fabricated the last 6 body mounts & tack welded them in. then removed the hood, front fenders, side panels, grill & radiator so I could jack up the body & install the body bushings (actually they're just rubber motor mount bushings for a '55 chevy...much cheaper) between the body & frame.
now that the body bushings are in place, I can mock up the steering shaft from the box to the column, mock up the throttle linkage, and mock up the bumper brackets.
the only thing I got done was the bumper brackets; here is a picture of the bumper mounted though the original holes in the body, to the tube frame.
also used clr & steel wool to remove the balance of the rust stains & overspray from the body & doors (that's the reason for the slight shine you can see on the body now).
this weekend, I will try to finish the steering & the firewall.
Old September 21st, 2016, 05:58 AM
  #63
1968_Post's Avatar
I look forward to your updates. This is my favorite build thread!
1968_Post is offline
Old September 21st, 2016, 06:27 AM
  #64
t23bucket's Avatar
thanks man!!!
Old September 21st, 2016, 08:44 AM
  #65
geez I got several favorites this is one too close to call lol
Old September 21st, 2016, 03:26 PM
  #66
t23bucket's Avatar
thanks, I appreciate it.
Old September 21st, 2016, 08:15 PM
  #67
steverw's Avatar
Wow looks nice, i would say this is not your first rod building rodeo. Ill keep watching your good work.
Steve
steverw is offline
Old September 26th, 2016, 08:44 AM
  #68
t23bucket's Avatar
Steve
thanks!! we've built a few drag cars over the years, but never really built a car for the street. it's a little different...easier in some respects (no cage, no nhra rules, not worried about vehicle weight, etc.), but harder in others (lights, ride quality, exhaust, street legal, etc.).
when I was a kid, my dad spent a ton of time with me working on hot rods, going to the dragstrip, going to swap meets...you know, the good stuff. we never had a bunch of money, so we bought what we could & built the rest. I used to love the swap meets.
I remember being 13 or 14 and going to a swap meet in Jefferson, WI; we had $100 to spend on parts, admission, & food. We left that day with a trunk full; we got a pair of unused M&H Racemaster 10.00x15 slicks, an aluminum moon gas pedal, a fram fuel filter, a set of forged pistons & rods...and a full stomach...those were the days. Unfortunately I think those days are long gone. I went to the same swap meet 2 days ago; what a bunch of junk...total waste of time. Anything worth buying was 3x what it was worth. It seems ebay has taken the entire market of car parts away from swap meets. It's a shame, it's hardly affordable for the average guy/kid to build a hot rod anymore.
Anyway, enough with the rant...back to the build.
Old September 26th, 2016, 08:51 AM
  #69
t23bucket's Avatar
so, now that I have the body on the rubber bushings, I wanted to finish the steering. I started at the steering box & worked my way back to the firewall. I had to cut the rear header tube (as the steering shaft dead headed directly into it. I simply cut the tube, flipped it around, & welded it back in. I used a rag joint & rag joint extension to a 3/4" tube. I also used a simple 3/4 round universal to assist in getting the column at a comfortable angle. to finish, I installed a heim to make the shaft solid (and adjustable).
Old September 26th, 2016, 08:59 AM
  #70
t23bucket's Avatar
I drilled a hole in my new floor & slid in a steering column; it seemed to sit pretty good. The next thing was to secure the column to the dash. Unfortunately, my car did not come with a dash. After searching for weeks for a 1937 Oldsmobile dash, I finally gave up. I did see one for upwards of 400.00, but there was no way I was paying $400 for a rusty piece of ****. So, I cut out the existing metal, cut more 3/4" angle (to use as framework), and welded it in.
I took some rough measurements, nibbled some .032 embossed aluminum sheeting for a template, and clamped it in. I also cut some guage templates out of cardboard and taped them to the aluminum.
It's not perfect, but it's a good start.
Old September 26th, 2016, 09:08 AM
  #71
t23bucket's Avatar
I decided to take a break from the interior, and move to the back of the car.
At the same time I was looking for a dash, I was also looking for a license light bracket...it seems these are worth their weight in gold as well. I found one online for only $600; I decided to pass.
I need to cover all the holes currently in the trunk, but do not plan on painting the car so I used a piece of cardboard as a template, traced a design big enough to cover the bolt holes, and made a cover out of 1/8" plate. I then drilled the holes, made a gasket out of some rubber sheet, and bolted it on the trunk.
For the license plate, I've decided to use an old parachute mount (as a parachute bolt pattern is pretty close to a license plate pattern). I bolted the plate to the mount & held it in place with one of my welding magnets. Next weekend I will connect the 2 pieces using 1/4 or 5/16 round-stock.
Old October 12th, 2016, 04:30 AM
  #72
t23bucket's Avatar
bent some 5/16" flat stock, welded it on to the plate mount I made last week; another item checked off the list
Old October 12th, 2016, 04:35 AM
  #73
t23bucket's Avatar
originally, I had planned on just ordering one of the speedway motors column drop mounts, but was concerned it may not be strong enough. it seems everyone pulls themselves in & out of cars via the steering wheel. I've seen wheels/columns flex, and did not want mine to.
I considered using one of my old aluminum connecting rods, but I think that method has been done a few too many times.
what I built may be a little overkill, and may be a little overthought...but it is adjustable, and should work fine.
I used a 1 3/4" collar (with set screw). I drilled and tapped it for two 3/8" bolts. I shortened some 3/8" tie rods, and bolted them to the collar on one end, and to a tab on the other end. this will allow me to raise/lower the column after I have the pedals & seat permanently mounted. once I have it where I want it...i'll lock it in place.
Old October 12th, 2016, 06:29 AM
  #74
Well that is certainly different...
Old October 12th, 2016, 08:50 AM
  #75
man that is some engineering going into that puppy, I am not sold on the license plate mount but that is just my taste LOL. don't mean a thing , it is certainly well executed, I like the steering set up..
Old October 26th, 2016, 07:45 AM
  #76
t23bucket's Avatar
thanks.
Old October 26th, 2016, 07:50 AM
  #77
t23bucket's Avatar
so, needed to figure out some small detail stuff before I take the body off the frame. I started with the shifter. I took some flat stock aluminum, bent it in a brake, and put it on the tunnel. I still have to round the edges, cut a taper, and build some angle brackets for it to bolt to...but you can see the basic idea
Old October 26th, 2016, 07:52 AM
  #78
t23bucket's Avatar
also started making the dash. I made the top part out of steel, broke it, and punched mounting holes. then I cut a flat plate of aluminum, cut some holes for gauges & switches, and bolted it in. it's not done...2 more gauges to cut in, but it's close.
Old October 26th, 2016, 07:55 AM
  #79
t23bucket's Avatar
the last thing I've done, I bought a few dynomax turbo mufflers, 3" in/out. bought some 's' bent pipes from hedman, and cut/tacked it together. it barely fits between the ladder bars & driveshaft loop...but it should work.
Old November 29th, 2016, 06:15 AM
  #80
t23bucket's Avatar
drilled the holes for the lower steering column support; bolted it in.
Quick Reply: '37 olds coupe build
