68 69 442 trunk drop off options.
FYI most of the readily available 1970 trunk drop offs are usable on a 68 or 69. The typical area that is rotted which is behind the tire on the lower portion of the panel to the trunk. Probably wouldn't be very helpful if you needed a complete drop off but only an option if you can use some of your original drop off.
