70 442 W-30... restoration
Old July 4th, 2013, 12:30 PM
  #81
briane's Avatar
Eric,
What finish should be on the inside of the rear wheel wells on your W30? I've seen restored cars with just about every alternative: undercoat, black paint, black paint with body color over spray, and all body color.
Brian
briane is offline
Old July 4th, 2013, 01:34 PM
  #82
jensenracing77's Avatar
It is a matter of what you want to do. I am not an expert and I have to look into each detail as I go and even then I am not exactly right. Mine will be the same color of black as the under side of the car with no overspray. The black will be just slightly less glossy than my frame. I will also not use any undercoat. As far as correct to be like it left the factory, I can't answer that. I have had low mile original cars with all different ways from the factory. This car had no undercoat originally.
jensenracing77 is offline
Old July 4th, 2013, 03:54 PM
  #83
No it's not a parts car!!
Schne442's Avatar
Eric, what did you use to paint the brake calipers? I used a paint kit by Duplicolor, it is a glossy black and i'm not to happy with it.
Gary
Schne442 is offline
Old July 4th, 2013, 09:14 PM
  #84
Gary
I spent more time on mine than i should have. I first painted them with a brake cast color from eastwood. after that I taped off all the machined surfaces and painted them with Eastwood Zinc Phosphate. I was going to use a matt black paint but I was out, I just grabbed the Zinc Phosphate because it is about the same. Now the machine surfaces look like they are bare steel.
Old July 4th, 2013, 09:15 PM
  #85
Originally Posted by joesw31
Eric,
Everything looks great! How are those brake drums...
I still need to get them turned to be sure I have a good set with life left.
Old July 4th, 2013, 09:18 PM
  #86
I don't think I am going to use the sway bars that I had powder coated. I think i am going to paint a set dark grey like the shocks. Anyone know what they were when the car came new? I know NOS is black but I don't think that is how they were when the car was new.
Old July 5th, 2013, 06:07 PM
  #87
I ran into some roadblocks. I do not have the bolts and hardware back from the plater and don't look like I will have them back any time soon. Hard to put together without bolts. I thought I would start on the engine but the machine shop is backed up till September at the earliest. Looks like I will just have to start taking the body apart.
I also ran into an issue with a hospital bill. I tried to get them to send me a bill for over a year. They would not send it to me and I forgot about it. Now 2 years later, I get a bill. Not only did I forget about it, it is also 2 times what I thought it was going to be. I told them I will make them wait 2 more years to get paid but they threatened to send me to collections if I make them wait that long. They even have in there records that I was trying to get a bill 2 years ago but there system also shows that one was never sent. I plan to see if they can cut the bill down. If not I will just send them $10 every now and then just to be difficult for them. Sorry for the rant.
Old July 5th, 2013, 06:19 PM
  #88
Sampson's Avatar
Eric, there is always something to do in the mean time! No problem on the hospital bill tangent. I ran into something similar a coupe of years ago. It was a technical issue where the administrator did not file some paperwork correctly. Long story short, that becomes my problem, and it goes to collections because I am stubborn and want to prove I am right. what a nightmare!
Sampson is offline
Old July 5th, 2013, 07:14 PM
  #89
NDERISE's Avatar
send a dollar a mounth
after read your deal with the heath bill I was going to tell u to send a dollar a month and they can't do u nothing because u are trying just not vary hard, put u will be trying harder than they were for 2 years
cars looking good and boy are u doing it fast
keep up the good work ray
NDERISE is offline
Old July 6th, 2013, 02:56 PM
  #90
I moved the cars all around so i could work in the body. I started pulling the interior out. The floor pans are great! I knew the bottom side was nice but the top is also nice. There is a very small amount of pitting on the passenger side of the transmission hump but that is all. I found more money under the carpet, nothing newer than 1981 when the car was parked.
Old July 6th, 2013, 08:22 PM
  #91
"Trying to fix her right"
dfire25's Avatar
Does your car have power trunk, or is that the rear speaker wire?
dfire25 is offline
Old July 7th, 2013, 03:48 AM
  #92
It is a speaker wire. The car has an AM with 8-track so it got the rear speaker.
Old July 7th, 2013, 03:53 AM
  #93
dfire25's Avatar
Ok thanks, I think the power trunk wire is run the same way.
dfire25 is offline
Old July 7th, 2013, 07:24 AM
  #94
NDERISE's Avatar
Thumbs up rear speaker grill
eric could u post a pic. of the rear speaker gill and may-be do u have an extra one to sell
thanks ray
NDERISE is offline
Old July 7th, 2013, 01:20 PM
  #95
They didn't have speaker grills. At least none of the cars I ever seen with a rear speaker had one. The package tray just had an area of holes in the backing of the mesh. I will take some pictures of that area of the package tray.
Old July 7th, 2013, 02:19 PM
  #96
davebw31's Avatar
NDERISE: no grilles! just as jensenracing states. the reason no grilles, as the speaker bolts to the bottom of the metal package shelf and the package shelf trim piece covers the speaker. there are two types of rear trim, one smooth (no holes) and the other is open mesh.
davebw31 is offline
Old July 7th, 2013, 02:22 PM
  #97
Ray,
Here are some pictures of the speaker area. Were there any grills available as an option? If so, mine didn't have one.
Old July 7th, 2013, 06:37 PM
  #98
NDERISE's Avatar
thanks
I guess the one with grills were dealer installed are an accessory u could install yourself I know I install some of these when I worked a the dealer but being I did it 40 year ago I don't remember what they look like thanks for the info. and the pics. keep up the good work with your car. will be at the nationals on the 23 of this month would u have any decent 70 front fenders u my want to sell.
thanks again ray
NDERISE is offline
Old July 8th, 2013, 02:16 AM
  #99
thanks again ray
What side? I have some but I would have to look at what I have.
Old July 8th, 2013, 08:24 AM
  #100
NDERISE's Avatar
Thumbs up both
I need both sides must be 70's, I will take a fender that would need a lower patch but must have a good inner brace behind it, I do have a very good r h 71 -72 fender if u would like to do some swapping
thanks ray
NDERISE is offline
Old July 8th, 2013, 08:50 AM
  #101
I will have to be sure but I think I have a set from a 442 with good braces but need the lower patch. Are they going on a 442? if so these would already have the correct holes. I will look at them tonight. Do you have an email address I can send pictures to. I will have room to bring them to the nationals if you like them.
Old July 8th, 2013, 09:56 AM
  #102
NDERISE's Avatar
Thumbs up Yes
Yes they will be going on my 442, would u be interrested in the 71-72 i have.
Email is rayderise@yahoo.com i think u my already have my email
thanks ray
NDERISE is offline
Old July 8th, 2013, 12:20 PM
  #103
I know I had it but finding it is not always easy for me, lol. I will get pics and send to you.
Old July 8th, 2013, 12:37 PM
  #104
Sammy70 455 Supreme
sammy's Avatar
Ray,
I think these are the speaker covers.....
Ted
sammy is offline
Old July 8th, 2013, 12:45 PM
  #105
Ted
Are these GM parts? I think it would look funny with a grill on it because it would only be on one side. I guess it wouldn't be that much differant than the defogger grill on only one side.
Old July 8th, 2013, 07:24 PM
  #106
briane's Avatar
I'm kind of an Olds neophyte, but I haven't seen speaker grilles used on the '70 Cutlass. I've owned a 70 Chevelle SS since 1975. Chevy did use a rectangular grille on the package shelf even with a single (passenger side) speaker. But the package shelf is solid cardboard. I'm also wondering about the grilles you pictured Sammy, they're like ones I bought aftermarket when I was compelled to remove the factory speaker from my Chevelle and install a pair of something that was promising to be just great but is now long forgotten (hey I was just a kid).
GM seems to consistently use blue wire to the rear speaker like Eric photo'd. I guess Olds just used a single wire and the body for the other conductor. Chevy used a blue/black wire pair.
briane is offline
Old July 9th, 2013, 05:05 AM
  #107
Sammy70 455 Supreme
sammy's Avatar
Hopefully somebody may chime in who may know..
Bought one from a fellow member and one came from a guy around here.
They do fit my 70 Cutlass, but I removed them because,like Eric eluded to, they looked kinda of weird on the package shelf.
I bought a new shelf instead.....
Ted
sammy is offline
Old July 9th, 2013, 06:29 PM
  #108
briane's Avatar
Well no one who apparently knows anything has chimed in yet, so I'll share the information from the factory publications. The Assembly Manual, Section 1, page 132, does not show a grille used with the rear speaker. The speaker is retained with special bolts, (which are currently available from InLine, OPGI, and others).
The factory Shop Manual Figure 15-13 shows no grille used with the fabric over hardboard (mesh) rear package shelf. They do illustrate a grille when a plain hardboard package shelf is used. I thought all the Cutlass' had mesh. Does the F85, for example, use plain hardboard (cardboard)?
briane is offline
Old July 10th, 2013, 05:00 AM
  #109
davebw31's Avatar
briane:
yes, however if the rear speaker option is ordered than it would have a mesh style rear package shelf. My Brass Hat F-85 had the rear speaker option and it had the mesh shelf! No grille.
davebw31 is offline
Old July 10th, 2013, 06:07 AM
  #110
NDERISE's Avatar
grills
grill were a dealer install option to the customer, I use to install them they came as a speaker kit with the wires, speaker and the grill
NDERISE is offline
Old July 10th, 2013, 05:53 PM
  #111
briane's Avatar
I should clarify my comment above, since a knowledgeable person had not yet chimed in, as someone who doesn't know much I though I'd go ahead and butt in.
Dave can you further explain the use of solid versus mesh package shelves? So if the vehicle came from the factory with a rear speaker it was fitted with a mesh shelf (and no speaker grille). If no factory speaker, the F85 received a solid shelf? What about Cutlass S, Supreme, 442?
Can someone tell me what the original rear speaker magnet looks like? Chevy had a small magnet in a rectangular frame like that illustrated in the Olds Assembly and Shop Manuals. Also pictured for Olds in the 1970 Delco Radio Service Manual. However I've seen a couple of high dollar restorations with a medium sized round magnet and no frame. My own car had an aftermarket huge magnet speaker in it when I got it. I replaced it with one from a 70 Chevy Dealer speaker kit.
Ray, on the Olds Dealer rear speaker kit, what did the grille look like? How about the magnet? Is the wire a single conductor or conductor pair?
Sorry to perpetuate hijacking Eric's restoration thread.
briane is offline
Old July 10th, 2013, 06:35 PM
  #112
davebw31's Avatar
briane: not real sure as this was not high on my list of "product quality control issues" or "high warranty items". Any Cutlass S and up models got the mesh shelf no matter if an option requiring it was needed. All base models lower than Cutlass S got the solid shelf unless a rear seat speaker or rear defroster option was ordered.
davebw31 is offline
Old July 10th, 2013, 06:47 PM
  #113
Rocketbrian's Avatar
My Arlington built 71 Cutlass Supreme SX without a rear speaker from the factory had the solid cardboard parcel shelf. It is my understanding, only the mesh was used with a rear speaker, regardless of model.
Rocketbrian is offline
Old July 18th, 2013, 04:42 PM
  #114
I got the rear end together. I am sure I don't have the colors exactly right but it will work for me. I will work on the brakes next.
Old July 18th, 2013, 05:52 PM
  #115
scott_442's Avatar
Awesome! Very nice work Eric. Looking forward to seeing the blue on blue. Might have to steal that combo for mine if it ever gets painted.
scott_442 is offline
Old July 20th, 2013, 10:52 AM
  #116
I still don't know for sure if that is what I am doing. I won't do black and I don't like white but white is starting to grow on me. I would just like to keep from going with a 3 color car. I have NO plans to sell this car after it is done but if I ever needed to I think the white would be more desirable than the blue on blue. I plan to look at some at the nationals and see what I like best.
Old July 20th, 2013, 10:59 AM
  #117
OK guys.... Don't laugh to hard. I don't have tons of experience with dashes but I had no idea that you could pull the wire harness with the dash. It always took me forever to pull dashes out. I thought I read somewhere where someone did it that way so I looked at it harder. I can't believe how much easier they come out this way. I only ever installed one dash and it took me a weeks vacation to get it right. I think I could have it in in less than a day now.
Old July 20th, 2013, 12:17 PM
  #118
charlierogers's Avatar
ha, I did the same darn thing! car is coming along great.
charlierogers is offline
Old July 21st, 2013, 08:07 AM
  #119
Sorry Dave, but I beg to differ. My 1972 Cutlass S (Lansing Fisher build date - 1st week of April 1972) came equipped with a solid cardboard parcel shelf.
No laughs from me! I found that out exactly the same way. Just pulled a dash at the bone yard recently and realized what you did AFTER I got it out.
That upper left side post caused me some worry (access) until I found out it was not fastened with a nut on the post. Coming along nicely Eric. BTW, why aren't you using the powder coated sway bar?
Allan R is offline
Old July 21st, 2013, 09:46 AM
  #120
briane's Avatar
Eric,
Eric your W30 is the same color as my 1970 Chevelle SS, code 28 which Chevrolet call Fathom Blue. I have a black interior. You also see 28 often with white interior which of course looks very good. I think, however, the blue interior would be nice as well as unusual. Actually I don't believe I have ever seen that combination. (I have often seen the blue interior in cloth with the lighter blue exterior Chevy called Astro Blue).
briane is offline
Quick Reply: 70 442 W-30... restoration
