70 Cutlass S Build
Old March 28th, 2009, 12:48 PM
wait.... what....
oldzzy's Avatar
70 Cutlass S Build
Hey everyone, i am new to the site. I have a 1970 Olds Cutlass S that i am in the middle of a frame off resto. Bluevista told me about this site, and it looks like a good place to hang out.
oldzzy is offline
Old March 28th, 2009, 12:58 PM
csstrux's Avatar
Welcome
csstrux is offline
Old March 28th, 2009, 01:06 PM
Nilsson's Avatar
Welcome, great site for sure and where do you call home.
Nilsson is offline
Old March 28th, 2009, 01:13 PM
69Rman's Avatar
Is this the same "Oldzzy" from London (Shane If I remember correctly) that came to look at those quarters that I had last summer?
How's the ride coming along?
Did you make up your mind yet on which trans setup you are going to use?
Post up some pics of that ride of yours. I remember the pics you showed me when you were here, it was looking pretty sweet then...
Share it with us all...
69Rman is offline
Old March 28th, 2009, 01:56 PM
wait.... what....
oldzzy's Avatar
Yes i am the same oldzzy that came to your place. I will find some pics and post them up, i did a lot of work to it after i met you. I ran outta nice weather tho, so i am looking forward to spring actually getting here. I haven't made my mind up on a trans yet but i am still leaning towards the TKO600. My job is not looking to good right now so things are on hold.
oldzzy is offline
Old March 28th, 2009, 03:25 PM
We look forward to seeing those pics. Welcome to the site.
Olds64 is offline
Old March 28th, 2009, 03:50 PM
Cameo White's Avatar
Smile
TKO-600? You must be building one heck of an engine for your car!
455 I assume?
Cameo White is offline
Old March 28th, 2009, 04:52 PM
Registered
Bluevista's Avatar
Hey Shane, Welcome.
Many thanks to J-(Chicago) for posting your ad.
He's one of the good ones.
I took the car out for the first time this year and was listening to the 8 track today. I got another faceplate and repo case but I think that case was better. The repo has lots of problems, they had to really try hard to make so many stupid mistakes.
The unit sounds good, just as bad as I remember, perfect.
I know you have pics, you put one on the letter when you shipped the unit, if it were my car I would too.
My Vista Cruiser would look really cool with those wheels.
Can you get them in woodgrain?
Bluevista is offline
Old March 29th, 2009, 06:05 AM
wait.... what....
oldzzy's Avatar
455 I assume?
The engine will be the original 350 built to make around 450hp. I want to be a little different and keep the 350, plus it's going to be a W-31 clone. The reason i am going with a TKO600 is because i want a 5spd, i was originally thinking of a T-56 but you need to do a lot more cutting to make one of those fit.
This how i bought the car
Taking it apart
Frame Blasted and painted
oldzzy is offline
Old March 29th, 2009, 06:09 AM
Past Administrator
Oldsguy's Avatar
There is some nice work there. Looking good.
Oldsguy is offline
Old March 29th, 2009, 06:17 AM
Snowdog's Avatar
Sweet
My first car was a 70 Cutlass S bought it back in 1981
for $500.00 it had 54,000 miles on it same color
Snowdog is offline
Old March 29th, 2009, 06:31 AM
wait.... what....
oldzzy's Avatar
next step is up on the rottisserie!
The drivers side had some rust issues. It had a few holes and some really thin spots, so i cut it out and put a new pan in. It was my first time doing this and man did i learn a lot lol After i drilled out all the factory spot welds and got the floor out i sandwiched back between the rocker panel and put in 280 sheet metal screws with hex heads to pull the floor pan tight to the braces and rocker. I then removed the screws, drilled the holes out a little bigger and plug welded the holes all in. A ton of time was involved.
oldzzy is offline
Old March 29th, 2009, 06:43 AM
wait.... what....
oldzzy's Avatar
Now time for sandblasting...
I managed to get most of the underside, firewall blasted, and drivers quarter sanded down to bare metal. This was done in late fall and i ran out of good weather so i decided to epoxy prime all the bare metal, and finish the blasting and sandind in the spring.
When i am finished (hopefully someday!), this is the look i am going for. The car won't be quite as low as the picture and the rims will be different style and maybe black centers with polished lip. The car in the pic was photoshoped lower by me.
oldzzy is offline
Old March 30th, 2009, 07:31 AM
citcapp's Avatar
Nice job on the floor pan. Looks like your well on your way to a nice restor
citcapp is offline
Old March 30th, 2009, 07:54 AM
Nice work
By the by, How do yo keep your garage so clean?
Jamesbo is offline
Old March 30th, 2009, 08:57 AM
csstrux's Avatar
That is one sweet rotisarie, did you fab that up yourself? If so I'd like a copy of the plans. Nice work by the way.
csstrux is offline
Old March 30th, 2009, 03:07 PM
wait.... what....
oldzzy's Avatar
Thnx guys, If you could see my garage right now you wouldn't think it's so clean!
My friend made the rottisserie for his 72 Charger, and i just made new mounting brackets to fit the Olds. He didn't have plans on paper, just in his head. I guess he just kinda winged it. It's a sweet rottisserie though, i can lower the car on it's side to 1/8" froom the floor so it's great for garages like mine that only have a 8' ceiling.
oldzzy is offline
Old March 30th, 2009, 06:22 PM
Registered Luser
ent72olds's Avatar
Lookin' awesome! Welcome to the site! I think this build should be posted in the Major Build Section...Also, looks like you are a wiz at photoshop! I need to learn a little about that. Gives a good idea on what could be!!!
ent72olds is offline
Old March 30th, 2009, 06:36 PM
wait.... what....
oldzzy's Avatar
This was the only section i could post in at the time as i was new.
oldzzy is offline
Old March 30th, 2009, 11:32 PM
Burning_Rubber's Avatar
Looks great,professional work for sure. Really enjoyed looking at the pictorial! Cant wait to see more pics of work in progress.
Burning_Rubber is offline
Old March 31st, 2009, 07:20 AM
citcapp's Avatar
Moved to major builds & projects by citcapp
citcapp is offline
Old July 26th, 2009, 01:32 PM
wait.... what....
oldzzy's Avatar
Not to much has happened since these pics but i have mounted my console brackets, bucket seat brackets, and cleaned up my clutch pedal setup.
IMG_2111.jpg?t=1248639905
from this...
DSC02307.jpg?t=1248640173
to this....
IMG_2117.jpg?t=1248640286
oldzzy is offline
Old September 10th, 2009, 05:29 PM
wait.... what....
oldzzy's Avatar
Started some sandblasting again. Finished underneath the trunk area, drivers and pass door jams, and the sides of the front cowl. Then i epoxy primed all the bare metal. I am blasting the top of the cowl, dash, and around the top of the windshield on Sat. Then i hope to get around the rear window done on Sun. Next week i won't have a ton of time so i am going to try and get the drivers quarter, and roof sanded and primed. Of course weather permitting!
I had the body and paint guy come buy and look at the car. He had turned down 4 or 5 other older cars but said he would do mine, so that made me feel pretty good.
IMG_2501.jpg?t=1252628260
IMG_2507.jpg?t=1252628835
IMG_2512.jpg?t=1252628877
IMG_2519.jpg?t=1252628910
oldzzy is offline
Old September 10th, 2009, 06:29 PM
meoff's Avatar
very nice work!looking forward to pics as you progress!I wish mine looked half as good as yours did when you decided to do a frame off
keep up the good work,and looking great
meoff is offline
Old September 10th, 2009, 06:44 PM
69Rman's Avatar
Yeah, thanks Shane....
...for making me jealous...lol
I've got to get over there and see this some time soon.
Looking really sweet man! Keep it up.
I may give you a shout this weekend if I find some time to myself.
Duane
69Rman is offline
Old September 10th, 2009, 06:52 PM
wait.... what....
oldzzy's Avatar
Hey Duane, i should be home Sat n Sun. Just give me a shout. You have my # ?
oldzzy is offline
Old September 10th, 2009, 07:16 PM
svnt442's Avatar
I looks great! But do you realise that you put the plugs in your new floor panel upside down? If you're just going for a nice driver then nobody will care. But some people might pick at you for it.
Just sayin.
Nice ride and keep up the good work!
svnt442 is offline
Old September 10th, 2009, 07:28 PM
wait.... what....
oldzzy's Avatar
Actually i didn't put them in any way, they come solid like that. If you want the original look, you have to cut them out.
oldzzy is offline
Old September 10th, 2009, 07:51 PM
car guy
gearheads78's Avatar
looking good keep it up
gearheads78 is offline
Old September 10th, 2009, 08:02 PM
svnt442's Avatar
Well that just blows.
Keep up the good work!
svnt442 is offline
Old September 12th, 2009, 07:24 PM
  #31
wait.... what....
oldzzy's Avatar
Well got back at it today and was right on schedule. Blasted the rest of the cowl, dashboard, and around the top of the windshield. After blasting i again primed everything. Hopefully tomorrow i will get at the rear window channel, the parcel shelf, and start on the inside of the trunk.
oldzzy is offline
Old October 6th, 2009, 11:00 AM
  #32
wait.... what....
oldzzy's Avatar
Well weather has sucked here lately but i finally got out and got the drivers quarter all sanded and ready for primer.
oldzzy is offline
Old October 6th, 2009, 11:14 AM
  #33
t bell's Avatar
Oh, that looks nice. I need a quarter.
t bell is offline
Old October 8th, 2009, 10:57 AM
  #34
wait.... what....
oldzzy's Avatar
Now Primed...
oldzzy is offline
Old October 8th, 2009, 01:10 PM
  #35
citcapp's Avatar
Taking shape keep up the good work
citcapp is offline
Old March 12th, 2010, 03:36 PM
  #36
wait.... what....
oldzzy's Avatar
Haven't done much work lately, but i have picked up some parts. This part being my fav! A NOS W-31 intake
oldzzy is offline
Old March 12th, 2010, 04:32 PM
  #37
Registered Luser
ent72olds's Avatar
Shane...NOS, for real! Couldn't have been cheap! Keep up the good work!
Old August 17th, 2010, 08:11 PM
  #38
wait.... what....
oldzzy's Avatar
Well a couple of steps backwards..... i decided to fix a couple of body mount holes in the frame that i should have done before i painted the frame. Lesson learned! lol
oldzzy is offline
Old August 18th, 2010, 04:14 AM
  #39
69Rman's Avatar
Nice work man!
It looks excellent, not that I would expect less from you.
I gotta get over again soon, got another stack of mags for you. Plus, I don't think I have gotten any of my drool on that intake yet...
Duane
69Rman is offline
Old September 1st, 2010, 02:43 PM
  #40
wait.... what....
oldzzy's Avatar
just working on the rear brakes now.
oldzzy is offline
Quick Reply: 70 Cutlass S Build
