Correct way to install the windowmolding clips?
Hello can someone tell me what the right way and order for assembling the front and rear windowmolding clips?
or is there a installation manual or pictures?
I am restoring a 71 442
thanks and greetings from the netherlands.
The first thing to do is install the clips onto the studs around the window. Once you have installed all of them, you will lay the trim over the clip at the edge of the window and press it down firmly. The trim lip will "clip" in between the clips and the body.
At the corners you will have to put the trim pieces together before clipping them in because they "slide" together. Hope this helps
ATrain1
Non-Olds Engines
June 29th, 2012 12:58 PM
oldzy
April 24th, 2010 09:13 PM
455for30y
June 27th, 2007 12:58 AM
