Down to the basic
Old March 14th, 2009, 04:21 AM
Captain of my ship
wolfman98's Avatar
Down to the basic
Well I took all the advice and changed the tranny filter and gasket and pulled the harmonic balancer to check the timing chain. The nylon gear on top was getting worn and the chain was pretty slack on both sides so now it has new chain and steel gears. I marked and pulled the distributer shaft and have started cleaning up the block. I will wait till everything is clean then pull off the valve covers. Anything I should be looking for while they are off ? I have been putting fresh paint on all the parts as they come off so it has gone slow disassembling it but once the block is cleaned up and painted it will hopefully go back together faster. ANY AND ALL ADVICE IS APPRECIATED AS THIS IS MY FIRST BIG BLOCK OLDS PROJECT. The last car I did much work on was a 327 back in 1976.
http://www.flickr.com/photos/wolfman98/
wolfman98 is offline
Old March 14th, 2009, 05:34 AM
Since the nylon timing gear deteriorated you should probably remove the oil pan and clean it. The chunks of nylon probably fell to the bottom of the oil pan. This won't hurt anything since they are too big to damage the engine, but since you are painting and freshening up the engine you might as well go the extra mile and pull the oil pan.
Olds64 is offline
Old March 14th, 2009, 08:39 AM
Captain of my ship
wolfman98's Avatar
oil pan
That was one of the first things i did . new gasket and seals and fresh paint while I had it off , I cleaned up the oil pump but did not replace it since it works fine and looks good.
nonhog
August 19th, 2013 10:50 AM
mefirst72
October 21st, 2012 09:14 AM
DeltaDevil88
Brakes/Hydraulic Systems
December 30th, 2011 01:57 PM
aviator34
June 28th, 2010 10:25 AM
deadbiker
March 31st, 2008 03:00 PM
Quick Reply: Down to the basic
