Gassed - another MAW disaster?
#42
Jack gets a big brother!
Now as Eric pointed out it would be a lot easier to work with more space under the car. PartSource had trolley jacks on sale and I found this really nice Michelin 3 1/2 ton job for 129.00 I told my Mrs. I really needed it. She's been driving me nuts with suggestions on how to finish emptying the gas tank - more on that later. Bottom line? My lil trolley jack I've been using for the past 15 years just got upgraded with a new BIG brother.
GMC can advertise all they want about professional grade. I just joined the party.
Nice or what?? 21 1/2 inch quick lift, rubber pad on lift plate, extendible rubber grip handle, lock release for flat storage and it will handle anything I'm ever going to throw its way. Makes my old jack look like a Matchbox imitation of the 'real thing'. I think I'll lift the car another 3 or 4 inches for clearance - should do the trick nicely. It will give a lot more room to drop the tank without getting it hung up either.
Now for the remaining gas in the tank. I figured out I was just not getting the siphon hose down far enough into the bottom of the tank. So here's what I devised since I was sick and tired of sucking gas into my mouth.
I cut a 6 foot length of rubber hose. In one end I put a 4 inch heavy lawmower wheel bolt, and then used a cement twist wire to make sure it wouldn't come loose. Taped over the end. Then I cut an opening into the hose. The weight on the end of the hose now allowed it to stay at the bottom of the tank.
Instead of sucking the gas through the tube? I cut a small slit in the hose just large enough to slip the pressure hose nozzle from the compressor. Gave it a shot of air and it acts like a venturi sucking gas from behind. Wish I'd done that earlier. So now there's only maybe a gallon or 2 left in the tank. MUCH better than before.
#43
OEM Parts needing restoration
After taking the bumper off, I took off all the hardware: license plate bracket, backup lights, tag light, rock guards and tail light pods.
The rock guards look decent but will get a general cleaning. The others need a pretty good (I see hours of wire wheel, sanding and detail work on them) amount of work to restore to new condition.
With the tail lights, I haven't figured out how to separate the wiring from the buckets. Anyone chime in and help on that? I did move one of the boots back to expose the plastic connector underneath, but don't know how the connector is attached. How does it come out, because in the meantime they are still attached to the car!!
The tag light has seen better days. I'll be able to get this looking like new and also should be able to clean up that lens with some of the new headlight clearing kits on the market.
The back up light mounts have some surface corrosion. Still, not bad for a 40 year old part.
I expect there will be a slight delay installing the new gas tank because the sender was ordered from ILT just this past Wednesday. So in the meantime it will give me plenty of time to look at restoring this stuff + pulling the rear springs/shocks and Maybe dropping that axle???
Oh look!! An eagle.....
#46
Larry, it would be great idea to do that especially if I was making it into DD, but I'm trying really hard to keep it as stock as possible. I know that 'stock' means as built to most, but I'm interpreting it to meet my needs of having as many period correct 72 options as possible. Might do the all wheel discs on a different project car though. Thanks for the thought!
Joe, which of the fasteners? The ones for the electrical or the bolts? Bolts I can get locally and cost is very reasonable. I normally buy a lot of my stuff from ILT because they have such a great shipping policy. BTW, last night I was looking through my bolts and stuff and found 4 new bumper bolts exactly the same as the ones that came out slightly corroded! I guess sometimes it does pay to be a packrat! Thought about ratcheting wrenches, but elected to buy air tools last year instead.
Thanks Shane. I'm going to have a look through those pics. Hope you don't mind if I PM you if I need some details explained?
#47
I owned a 71 supreme for years and the bumper bolts were different than my 70 and I say MAW get new bumper bolts...
http://www.ebay.com/itm/71-72-olds-4...item2569343d4e
#50
#51
The choir has spoken
Thanks guys! I'm glad to hear that you feel the same way I do about it. I wish to God I'd taken a more serious interest in doing all these things myself much earlier in life. Well one thing anyway. If I run into stumbling blocks periodically I have a great support group who can help me through pretty much anything I've tackled so far. That's a personal comfort for me.
Joe - the bumper bolts I found are exactly the right ones. Not sure why 1970 would be any different. When I go down to Part Source, I plan to take all the samples I need to replace just to be sure I'm getting the right phosphate coated stuff I need.
Now if I ship this baby down to TX when it's done, I just know y'all will have fun with it huh? I think there's more members (registered and at large) in TX than just about anywhere in the US of eh! Sorry, couldn't resist
#52
Yep, Steve and I would have a great time! However, I get to drive first. If this is the case, then, MAW drop a 455 in it for our enjoyment.
#53
Yer killin me here Joe! I'd ship it down with it's 350/350 and let Steve drop in a 455/400 for me. You know how bad he wants another 455 project right? THEN you could take turns impressing the local chicks
#54
#55
And I would be ok with that. You'll also need to install buckets, console, change the column, speedo, add clutch pedal, z bar yada yada. But I KNOW it would be a totally cool car when done by people that KNOW Oldsmobile. You know I'd have to be there to lend a hand and learn at the same time right?? You might need to install a beer fridge for that build.
#61
You know, in a couple track videos from '71 they were testing out a w-30 convertible that had a 4 speed floor shift WITH a front bench seat!
That's the way to have a sports car. With two babes in the front, one sitting between your sick.
Wait.... I could do this...
#63
This is the culprit
Here's that pic I promised ya earlier when I found the gas leak. I'm indebted to Tony for helping me find this sooner than later. Could have been out for a cruise with the Mrs. and had the rear end catch fire. It looks like the leak is from the top seam on the right side and goes down the tank - pooling and dripping in close range to a hot exhaust.
#64
#66
Wutchu talkin bout Ted? You're way younger than me, and Tony is less than 1/2 my age. Older is better buds! We gets better breaks on most everything including insurance. And BTW, who says chicks don't like grey hair, a friendly smile and no fear of rejection by paying them a compliment about their looks/endowment??? I don't wear my ring when I'm working on the car and sometimes I 'forget' to put it on when I'm going shopping. Don't think for a second they don't look to see whether sugar bear is attached...
#67
Just so I know, where is the point of no return, where do the MAW's stop for this project? and how do you control them? Maybe, I should ask you later once the fog lifts.
#68
After this statement, I'll bet the Mrs thinks you have been huffing too many gas fumes while siphoning the gas out of the tank. LOL.
The point of no return was when I put it up on the Jack stands....everything just seems to evolve from there. Believe it or not there's some method to the madness, just not sure where...
I control the MAWs by creating white MAW cells. Thousands of them, like Mitichlorian that controls 'The Force'. Every so often though they run up against the Dark Lord (Rob Young and company) and during the ensuing battle other parts of the car mysteriously come off in my hands... but I usually have my trusty camera out in the garage to pinpoint what happened.
So I guess in that roundabout explanation, the MAW factor is actually controlled by the Green things in my wallet. No $$$ = no project. Also, no parking spot in the garage over the winter for my Mrs. = a VERY LONG COLD winter if you get my ... drift..sorry couldn't resist the SNOW JOB! Almost like being caught in a 'blizzard' of Austin Powers jabber, huh?
#71
So the next step was to drain the fuel. I think the lesson here is why wash your mouth out with soap when you can do it with gas?? awweekkk, ptui!!! Repeat as needed. The gas gage says the tank is 3/4 full but I know that means it only has about 12 gallons. Got 5 gallons out without much effort, so I emptied the jerry can into my waiting Sonata. I had run the Sonata lower than normal to help out with this.
Back to the trough to get some more gas. Can't seem to get it flowing again even with a longer hose. And I'm tired of tasting gas in my mouth...there's gotta be an easier way to do this.
It's the same principle as putting your finger over the end of a straw that's in a drink and pulling some of the drink out with the straw. It keeps you from getting a mouth full of gas and starts the siphon easily.
Allan, when you put a new sending unit in the tank you MAW put in a RobbMC 1/2" pickup unit to feed the new engine I hear we're putting in it. From what I've gathered so far we are doing a twin turbo 496 stroker with a 4 speed Muncie? Oh, and a bench seat lmao!
P.S. when you get ready for buckets I have a really nice console I've been trying to sell...I'll make ya a smoking deal
#72
#73
I wish I could've helped sooner...but here's a tip for future reference. When siphoning gas, use a 3/4" clear hose about 5' long. Insert as much as you can into the tank, then while holding the clean end, put a kink in the hose with both hands. ABOVE THE TANK, put your mouth on the hose and loosen the kink slowly while you suck on the hose. Repeat until you get gas about 1" from the kink. Hold the kink tight, with the gas in the hose and lower it below the level of the tank...then release the kink.
#74
You know something I don't my Dark Lord??? You're assuming there will be a next time...Hmmm, maybe the neighbors don't have locking gas caps....NOW look what you've gone and done.
#75
I had everything up until last year. I planned on converting my car but after sitting in another persons bucket seat car I realized I'm not comfortable in them. Its the leg cancer thing ya know? Anyway, I already sold the bucket seats, the NOS Dual gate, the NOS top plate (D/G), but I have the console and wiring harness still along w/ the floor mounts for it. I paid so much money for a restored console & now I'd like to just get rid of it. Its not gonna get used.
Sorry to say but my bench seat (w/ 2" relocation brackets I made) is the most comfortable way for me to ride in the car
#76
Heck Steve, no reason to apologize at all. I remember what we talked about in the PMs. Chances are I'm not going to go with buckets for my car. I originally thought it might be a good idea, but after reviewing the cost to refurbish them, add console, change carpet, speedo, column I just didn't want to go to all the hassle. Almost as bad as buying a Thornton hood and I have higher priorities for the $$. My Son and his college.
#79
ah!! I see you've been under the car!!! Any chance of taking a pic of that elusive air dam attachment I'm looking for? IIRC you said you have one
#80
Freshly recovered front bench seat, CHECK!
If its for a good cause you guys can totally borrow it. I didnt torque down the bolts "that" tight when i installed it.
Actually, i've started keeping a guestbook in my car. Each new girl i take for a ride writes a quote.
